Utility Sink Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2015, 09:16 PM   #1
Rewards Points: 4
Utility sink installation
Hi there, My name is Peetsi and this is my first time on here and was wondering if you can help me with something? I was told that it would cost me 1200 dollars to install a utility sink in my garage and take up to 8 hours to finish.....Why is it so expensive? Can I try doing it myself? Cutting thru the wall, rerouting pipe......???
Peetsi is offline   Reply With Quote
Old 05-11-2015, 09:30 PM   #2
Rewards Points: 1,942
Make a few post I think four then post some pics of what you intend to tie into.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Peetsi (05-11-2015)
Old 05-11-2015, 09:32 PM   #3
Rewards Points: 18,976
No one here is going to know if it's an attached garage, where you even live, what its going to take to run the supply's and and drains to the septic system, what local labor rates are, what local codes are without a lot more info so they can make a guess.
Tried getting some more quotes?
Peetsi (05-11-2015)
Old 05-11-2015, 09:36 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 258
Peetsi, welcome aboard!
If you're somewhat handy, this is something you might be able to tackle.
Like Ghost said, a couple pictures of your connection points or any questionable areas would be nice.
Old 05-11-2015, 09:43 PM   #5
Rewards Points: 4
Sorry.....I live in Eugene, Oregon. My garage is attached to house. My utility sink is going to be about 6 feet away from my washer..I believe I have plastic ABS pipe...I will get a couple more quotes and see if I can send some pictures.....thanks for your input.
Tags
plumbing , utility sink
old cement utility sink helpmyhusband Plumbing 31 09-26-2016 07:53 AM
Drain Q: Basement Utility sink move from one side to the opposite amb1s1 Plumbing 21 03-28-2013 02:06 PM
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
Installing utility sink next to washer/dryer cuseguy Plumbing 2 12-30-2008 05:09 AM
