Used Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2016, 04:48 PM   #1
Rewards Points: 32
I am able to get a hot water heater that is an exact match to the one I have in my trailer now. My existing hot water heater is still working fine but not sure how much longer it will last so this would be good to have espically since it is free. Only two problems.
1. They cut off the old pipes. How do I attach new ones?
2. Since I won't be using it right away, how do I store it and not have to worry about it rusting inside? When they drained it I was told it didn't have any sediment.
Thanks for you're reply's
reggae5 is offline   Reply With Quote
Old 10-21-2016, 05:03 PM   #2
Rewards Points: 18,762
Re: Used Hot Water Heater
Last thing I'd buy is a used water heater.
Those old pipes should just unscrew.
Old 10-21-2016, 05:38 PM   #3
Rewards Points: 32
I didn't realize they are only screwed in. Thanks
Also I didn't buy it, it was free, so nothing to loose
Old 10-21-2016, 06:02 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,586
I would flush it myself to be sure there was no gunk in the bottom and then store it dry.
The Following User Says Thank You to joed For This Useful Post:
reggae5 (10-21-2016)
Old 10-21-2016, 07:37 PM   #5
jlhaslip's Avatar
Rewards Points: 708
The best way to tell if it is loaded with gunk is to lift it and then go find another new one and lift that one. Guaranteed the old will be lots heavier if it is all scaled up.
Good score!
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-21-2016, 07:54 PM   #6
Rewards Points: 32
Good score!
Thanks for that tip. Edmonton -mmmm almost moved there in 1970 headed south and moved to Key West instead
Old 10-21-2016, 08:03 PM   #7
jlhaslip's Avatar
Rewards Points: 708
Good call!
But you miss all the good snow...
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
