Use A Saw On Toilet Bolts? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
  • 1 Post By Dave Sal
  • 2 Post By hkstroud
  • 4 Post By MTN REMODEL LLC
Old 09-05-2017, 11:33 AM   #1
Rewards Points: 2
Use a saw on toilet bolts?
Water started to leak from toggle bolts holding the tank to the toilet base. Tightened the bolts & OK for a while then started to leak again. Drained and dried everything and applied caulk to the bolts inside the tank. No more leaking.
Now there is water leaking from the base (caulking missing where it leaks). so I'm thinking I must replace the wax seal but how will I remove the bolts?
dyigrrl is offline   Reply With Quote
Old 09-05-2017, 12:08 PM   #2
JUSTA MEMBER
Rewards Points: 3,882
Re: Use a saw on toilet bolts?
There should be little plastic caps covering the bolts
If not can you provide a picture of it, so we can see how to advise?
ED
de-nagorg is online now   Reply With Quote
Old 09-05-2017, 12:28 PM   #3
ZTMAN's Avatar
Rewards Points: 628
My bet is she is referring to the tank leaking Ed. We will have to wait for her to describe the problem.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 09-05-2017, 12:52 PM   #4
Rewards Points: 6,430
If we're talking tank bolts, mine were easier to drill the heads off from inside the tank than attempting to saw them off from below. I sharpen my bits on a bench grinder but if one isn't into that sort of thing I recommend purchasing a new quality 5/16" high speed steel ( HSS ) drill bit before making the drilling decision.
Old 09-05-2017, 01:06 PM   #5
Dave Sal's Avatar
Rewards Points: 646
I had problems removing my tank bolts years ago. A Dremel tool makes quick work of that job.
SeniorSitizen likes this.
Dave Sal is online now   Reply With Quote
Old 09-05-2017, 01:10 PM   #6
I posted about the usefulness of a dremel a few years ago and a supposedly upstanding member criticized for using a toy as a tool so I quit mentioning them but still sure use it when necessary.
Old 09-05-2017, 01:34 PM   #7
Dave Sal's Avatar
Rewards Points: 646
I know what works for me, and could care less about what anyone else says. You've given out some outstanding advice since I've been reading this forum, and am surprised that you would let someone sway you that way. Dremel's are great tools.
lenaitch likes this.
Old 09-05-2017, 04:36 PM   #8
hkstroud's Avatar
Rewards Points: 6,694
Well I'd bet that your sawsall blade will fit between the tank and the toilet bowl. Or your oscillating multi function tool.
I've got little tool also but I'm not going to talk about it.
MTN REMODEL LLC and Nealtw like this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
MTN REMODEL LLC (09-05-2017)
Old 09-05-2017, 05:02 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
I've go little tool also but I'm not going to talk about it.
HK......
Many years ago, we were in a credit committe meeting (back in the "suit" days) and the secretary was going around the table filling up coffee cups.... and came to Richard Kaufman.
She asked..... "Would you like a little...Dick"
he responded.. "No thanks, I've got one... but I'd like some coffee."
It was 20 minutes before we could get back to business.
Best
MTN REMODEL LLC is offline   Reply With Quote
Tags
plumbing
Kohler 1.6 g Triangle spud gasket, 3 bolts, leaking; ? about order of washers/nuts lazzlazz Plumbing 5 07-03-2017 01:21 PM
toilet paper holder boilermaker27 Plumbing 2 09-13-2013 06:10 PM
Broken toilet bolts elmaur Plumbing 9 10-18-2012 05:37 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
