Use Grease On Replacement Amer. Std. Cartridges? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2015, 03:07 PM   #1
Rewards Points: 364
Use grease on replacement Amer. Std. cartridges?
Have American Standard "Williamsburg" tub & shower faucet.
They sent replacement cartridges for the water control & the "pressure balancing cartridge" - (maintains hot & cold balance).
Should I grease the o-rings & seals before installing new cartridges?
Per A.S. support, the only instructions on installing them are from the original "rough in & installation guide."
Install: http://www.americanstandard-us.com/a...stall_2164.pdf
Parts: http://www.americanstandard-us.com/a...Parts_2164.pdf
Nothing mentioned about using grease (e.g., silicone) on the seals / surfaces, before inserting new cartridges in this tub faucet (many gaskets, seals).
For an A.S. , single handle kit faucet I have, they sent instructions w/ replacement parts & included silicone grease. Mentioned places to apply the grease.
Thanks.
tearitup is offline   Reply With Quote
Old 08-05-2015, 03:12 PM   #2
Rewards Points: 5,348
Following the instructions is generally a good thing.
I always use a faucet grease on all the robber parts when I switch cartridges.
Reduce friction, reduce wear.
Ron
B. Franklin 1759
Old 08-05-2015, 03:25 PM   #3
Rewards Points: 364
That's just it - for the Tub & Shower faucet, there's no mention of grease (any where I've looked). But these 2 cartridges have tons of rubber seals, o-rings.
Old 08-05-2015, 08:36 PM   #4
Rewards Points: 364
My short answer is, hell yes. Slather it up w/ silicone!
Too tired now for all details now.
But after taking ~ 30 min to get the temp balancing cartridge out (it broke off, from o-rings leaking? & lime holding it tight).
Then another 1, 2, 3 hrs (lost track) to clean lime off the "important areas" inside the brass valve body - W/O marring sealing surfaces, I made sure minerals won't stick to much of anything inside there - plastic, brass or otherwise.
Trailer bearing grease packing - are we packing the bearings? Or the hub? jkeuning Automotive Repairs 8 07-30-2015 08:27 AM
Dielectric Grease -vs- Silicon Grease silvercbx Electrical 3 08-09-2013 12:59 AM
General and Specific Questions on Clutch Replacement 2000 Celica GTS amodoko Automotive Repairs 24 02-25-2013 01:59 AM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
