Urinal Back Wall Options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2015, 09:08 PM   #1
Rewards Points: 290
Urinal back wall options?
Just curious what all of your thoughts are regarding what to put behind the urinal?
I was originally considering tiling the wall with a subway tile for sanitary reasons, but I'm now wondering if I could get away with just painted drywall?
What would you do in your home?
gizzygone is offline   Reply With Quote
Old 12-30-2015, 09:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 170
Not paint- you ever seen what urine does to paint surfaces?
Use tile, FRP, PLam, anything thats washable and nonporous.
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (12-31-2015)
Old 12-30-2015, 09:47 PM   #3
Rewards Points: 290
Haha, no. I actually haven't! But I'll take your word for it!!
Old 12-30-2015, 10:57 PM   #4
Rewards Points: 1,854
Use this
http://www.njsupply.com/4X8-White-Fr...l_p_69337.html
Old 12-30-2015, 11:36 PM   #5
Plumber
Rewards Points: 170
IMO, Id probably find a real nice laminate that looks like granite. I just recently did my kitchen counters with it and it looks great.
My second choice would be tile. I feel its more labor intensive than a sheet product.
FRP is good too if you want the restaurant/industrial look
Botton line is somethig stain resistant, waterproof and cleanable
Old 12-31-2015, 12:15 AM   #6
Rewards Points: 6,652
Eplumber you can actually now get FTP in other choices than the tradition raindrop White stuff you see all of the time in restaurants. The only reason for the white is so that they can tell if the place has actually been cleaned or not.
http://www.marlite.com/designer-wall...ll-panels.aspx
Old 12-31-2015, 09:28 PM   #7
Rewards Points: 1,956
Urine big trouble if you use tile back there, the tile might clean up but the grout won't. Go with the laminate. Also a good spot for plastic baseboards.
ChuckF. is offline   Reply With Quote
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 02:44 PM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 06:22 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
