Uponor Setup Time/UV Precautions? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2016, 03:41 PM   #1
Rewards Points: 290
Uponor Setup time/UV precautions?
Two questions about Uponor:
I read somewhere that it takes Uponor about 30minutes to regain its shape after expanding to the fitting: I waited an hour, and when I pressurized the branch I had water leakage at a fitting.
Now, the PEX isn't FULLY seated on the fitting, but it does envelop all of the ridges. It's now been 48 hours, and I was about to replace the line, but I decided to pressurize it once more, and voila! No leaks?
Would you replace the tube anyways? Or do you think the 1hr just wasn't enough for it to clamp down the first time?
Also, I'm an idiot and left the PEX in my garage for about a month after delivery. It wasn't in direct sunlight, but sun does get in. Some of the PEX I had ordered didn't come in a UV resistant packing: is there something to look for that's telling that PEX has been over-exposed to UV? Or should I just toss it and buy new?
Finally: how crazy do I have to go to prevent UV from exposing the PEX? I've been to some friends houses with unfinished basements, and the sun is coming in thru the basement window exposing the PEX for years (unprotected). Do I need to go nuts covering the PEX with foam insulation? Or should I just cover my basement Windows (drywall won't be going up for a couple months)
gizzygone is offline   Reply With Quote
Old 02-02-2016, 04:57 PM   #2
Civil Engineer
Rewards Points: 5,246
I use the same system. My experience is that 20 minutes is adequate to seat the pipe on the fitting. It really is important to seat the pipe completely, the only time I have ever had a leak on a new fitting is when I failed to seat completely. As to storing the pipe in partial sun, it is certainly not recommended, but probably not a huge problem unless it was there for a year or more. Direct sun, that would be a more serious issue.
Old 02-02-2016, 05:54 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.... I use the same tubin', 'n think the UV light thing is Waayyy overblown on the internet,....
I wouldn't leave a roll layin' out in a field for 5 years, 'n expect to use it,....
No different than PVC,....
I don't cover it from indirect/ direct occasional light,... no problems,.... yet,...
I'm 'bout 5 or 8 years into usin' the stuff, 'n still Love it,....
I use the ssteel crimp-rings, rather than the expander, so I can't attest to it,...
I bought the crimper tool, 'n rings are cheap enough,...
Any leaks I've had, heatin' the tubin' abit, 'n retightenin' the crimp ring sealed it up,...
The Following User Says Thank You to Bondo For This Useful Post:
Chris130 (02-02-2016)
Old 02-02-2016, 06:21 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I been using the pex for about 20 years, started with radiant heat and then into domestic water, I use the copper crimp rings..the secret if you have a leak on a fitting after crimping or expanding in your case..apply a little heat and that gets the pex molecules to go back to there memory..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Old 02-02-2016, 08:50 PM   #5
Rewards Points: 290
Alright... Sounds like I'm good to go then. I did quite a bit of expanding using the Milwaukee tool to buy myself time to attach the PEX to the fitting. Plus it's in the basement which is a bit cool this time of year.
Perhaps the hour I let it sit wasn't enough in that climate? I have it at full city pressure now without an apparent leak (knock on wood) so I guess I'll leave it alone.
Glad to hear the UV ratings are a bit over rated. I didn't want to waste $60 if not needed.
What precautions to take to prepare for power loss BCSapper General DIY Discussions 16 10-21-2014 01:08 PM
Precautions for cutting this stuff Dorado Flooring 2 04-01-2013 04:16 PM
Precautions when disinfecting the well Sam Alex Plumbing 10 07-24-2012 11:24 AM
possibly basement finishing project, precautions? fabian Building & Construction 2 02-27-2011 11:48 PM
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 04:14 PM
