Upgrading NG Service ~ Inside Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2015, 01:01 PM   #1
Rewards Points: 129
Upgrading NG Service ~ inside plumbing
Hello Experts and thank you for your time,
I recently went thru an oil to gas conversion. My gas supply company has informed me that they need to upgrade the service to my house to accommodate for the additional load. They are running the new line and installing the meter at no cost to me, but the new piping that needs to be done inside the house is my responsibility. i am no stranger to running gas lines and am very comfortable doing so myself. I pressure test all my work and have the blessing of the local town inspector to handle my own gas piping.
The existing service meter is in side my house. coming off of this meter into my house is 1" pipe which gets reduced to 3/4ths to feed the various appliances i have running off of it (Water Heater, Boiler, Stove, Dryer)
My Utility company is telling me that when they install the new meter, they want to see 2" black pipe coming thru the wall to the new service location outside my house.
Is it acceptable for me to tie this 2" pipe into the 3/4ths existing piping? I've never worked with 2' pipe before, so I dont know if there are different rules for this, or can i pipe it just like the 1" supply was done. Also, not sure i've ever seen a 2" to 3/4 tee but i never really looked either. I was also hoping to put a 2" shut off inside the house but cant seem to find those either.
AdamBNYC is offline   Reply With Quote
Old 12-03-2015, 03:03 PM   #2
Rewards Points: 129
nevermind, figured it out. Sanity check, 2" trunk stepping down to 1" or 3/4" branches depending on load/drop. Sound about right?
The Following User Says Thank You to AdamBNYC For This Useful Post:
Ghostmaker (12-03-2015)
Upgrading to 200 AMP service panel beamar Electrical 8 04-26-2011 12:43 AM
Upgrading water supply plumbing...where to locate filter? Jim S. Plumbing 3 02-06-2009 11:13 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Upgrading Service to 200 amps sandyman720 Electrical 6 03-30-2007 05:37 AM
Upgrading service sandyman720 Electrical 1 03-15-2007 04:48 PM
