Upflush Toilet Can I Plumb A Sink Going To A Shower And Then The Shower Feeding Into - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2017, 11:00 AM   #1
Upflush toilet can I plumb a sink going to a shower and then the shower feeding into
Upflush toilet in basement can I plumb a sink going to a shower and then the shower feeding into the flush toilet basin.
My everbilt upflush toilet can be hooked up to a shower and a sink but the 2-inch pipe from the shower and sink must be six and a half inches up from the bottom of the basin
So I plan to dig my basement out so that I can put the basin four inches down below the top of the slab then fill the perimeter with concrete to lock it in place
I have a question about how to do the rough plumbing can I have the sink drain line feed to the shower drain line then have the shower plumbed into the toilet?
Essentially can I have them running in series?
In the first picture I point to where I will have the shower drain line punched into the basin
In the second picture I point to where I want to have my sink and shower my shower on the left and my sink on the right
Upflush toilet can I plumb a sink going to a shower and then the shower feeding into -1497196692430242574846_1497196707314.jpg   Upflush toilet can I plumb a sink going to a shower and then the shower feeding into -1497196760555537403865_1497196778892.jpg
Drewbabich is offline   Reply With Quote
Old 06-11-2017, 11:32 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,996
Re: Upflush toilet can I plumb a sink going to a shower and then the shower feeding i
If you are going to dig why not just install an ejector pump in a sewage basin..
Old 06-11-2017, 01:50 PM   #3
Rewards Points: 1,950
How do you plan to get the three inch vent out the roof?
The documentation for this thing say nothing regarding adding a shower and a sink. Make sure you get all your permits including plumbing electrical etc for this project. Without knowing the state and code that applies it's hard to offer good advice.
