Unmovable Union Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2016, 09:43 AM   #1
Rewards Points: 47
Angry
Unmovable union fittings
Finally got around to changing that old laundry faucet. But of course, ran into a problem. I cannot get the union fittings to move at all highlighted in the picture.
And before anyone says "I need to remove the nuts below first." I did that already and got stuck afterwards. This picture was taken after I put the old faucet back on. Then I thought I would just reuse the old unions and nuts since they weren't leaking and so tight, but no! The hot side fits on the new faucet, but not the cold side.
Is there a special tool I should be using? I've tried pliers and vice grips already. Or am I going to have to remove more pipes just to get at these unions? Not shown in the picture is a pair of shut off valves for the washer hoses. I can take more if necessary.
Sliding Man is offline   Reply With Quote
Old 03-01-2016, 09:52 AM   #2
Rewards Points: 3,668
With the union nuts loose, two 14" pipe wrenches will do it to it if you turn the correct way. Be aware the pipes will be getting longer by 3,4 or possibly 5 thread pitches as you unscrew.
Pliers, channel locks and vice grips are a sure sign of amateur plumbers.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Sliding Man (03-01-2016)
Old 03-01-2016, 10:03 AM   #3
Rewards Points: 18,384
#1, So far your using the wrong tools. Vise grips are going to crush the fitting and there's not enough leverage.
#2, 100 % sure your turning them in the right direction? Should be turned from left to right.
If you can get that spout off it would give you more room to work.
Try using a real open end wrench. May have to give the wrench a tap with with a hammer to break them free.
If that does not work may have to go to about a 14" pipe wrench.
Are those Pex supply lines?
Old 03-01-2016, 10:18 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 264
Ayuh,.... Use 2 pipe wrenches,....
One to hold the pipe, 'n one to turn the fittin',....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 03-01-2016, 12:20 PM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
eat your wheaties...um well second thought dont..you might grow long hair and ----..LOL..try a little heat from a propane torch, does wonders for stuck stuff, and 2 pipe wrenches..
WhatRnsdownhill is offline   Reply With Quote
The Following 2 Users Say Thank You to WhatRnsdownhill For This Useful Post:
dd57chevy (03-01-2016), Sliding Man (03-01-2016)
Old 03-01-2016, 06:32 PM   #6
Rewards Points: 582
yep need 2 pipe wrenches...but just a thougth..why not remove old galvanized pipes to the upper fitting and replace piping from there.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 03-01-2016, 08:27 PM   #7
Rewards Points: 47
Too lazy to change more of them. But get this, the guy I talked to yesterday at HD told me my channel locks would be enough. Sure enough, I took all of your suggestions and brought 2 pipe wrenches and they came right off with ease.
The Following 3 Users Say Thank You to Sliding Man For This Useful Post:
ben's plumbing (03-01-2016), Bondo (03-02-2016), dd57chevy (03-01-2016)
Old 03-02-2016, 05:50 PM   #8
Rewards Points: 994
Smart person, ignored the big box store and listened to those here.
fireguy is offline   Reply With Quote
Old 03-02-2016, 06:06 PM   #9
Maybe they were short handed in plumbing that day and moved a guy over from the crafts department.
Tags
faucet , impossible , leak , stuck , union
Faulty brass pex fittings ddsrph Plumbing 6 05-09-2014 07:23 AM
Sharkbite Fittings davidblackwoods Plumbing 55 06-14-2013 09:14 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 10:16 AM
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 09:47 AM
