Unknown Pipe In Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2015, 01:58 PM   #1
Unknown pipe in garage
Moved into a new place and there is an unknown thick pipe protruding out in my garage. Can you please help me figure out what is it for ?
Here is the link to the image of that pipe in my garage.
http://imgur.com/iFeoOgd
http://imgur.com/tqJWy4o
johngtheplumber is offline   Reply With Quote
Old 11-15-2015, 02:16 PM   #2
I am not able to post image link since this is my first post.
Old 11-15-2015, 02:17 PM   #3
Old 11-15-2015, 02:38 PM   #4
Rewards Points: 3,234
Interesting pics. Looks like a 3 or 4 inch pipe capped off for future toilet or something to do with a septic system perhaps. Just guessing.
Others will be along with more suggestions/advice.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
johngtheplumber (11-15-2015)
Old 11-15-2015, 03:13 PM   #5
Property Mgt/Maint
Rewards Points: 8,188
generally you need about 12" for a toilet drain to the wall. How much distance do you have from the centerline of the pipe to the wall?
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 11-15-2015, 04:25 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,700
Looks like either a sewer or a well. Can you take the cap off and look inside?
The Following User Says Thank You to joed For This Useful Post:
Old 11-15-2015, 05:52 PM   #7
Rewards Points: 18,808
Looks to close to the wall to be a toilet drain.
Should be about 12" from the finished wall to be a drain.
Clean out?
Old 11-15-2015, 08:40 PM   #8
Rewards Points: 1,866
Clean out.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
oh'mike (11-16-2015), TheEplumber (11-15-2015)
Old 11-15-2015, 09:35 PM   #9
It is 7 inch from the finished wall and 5 1/2 inch in diameter. I am not able to open it and looks like it is locked with something.. If it is a clean out, will I need to open it in the future or is it sealed ?
Old 11-15-2015, 09:48 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 186
My guess is a clean out or a capped hub drain.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 11-15-2015, 10:16 PM   #11
Just leave it alone. If you ever need it to clean out a sewer make sure you notify the plumber.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 11-15-2015, 11:54 PM   #12
Super Moderator
joed's Avatar
It looks like a simple band clamp if you need to open it.
johngtheplumber (11-16-2015)
Old 11-16-2015, 12:19 AM   #13
Yea, I think it is a band clamp. Have never opened one and so want to make sure that if I open it, I am able to close it as it is. Checking for some videos online, but if you have any tips, I would appreciate it. Thanks.
Old 11-16-2015, 06:23 PM   #14
Uses 2 radiator clamps just undo them and pry it off the rubber may be stuck on.
johngtheplumber (11-22-2015)
Old 11-16-2015, 10:44 PM   #15
Rewards Points: 268
Looks like the 2 pipes in my moms garage. They used to pick up 2 drain pipes from the 3rd floor gutters, through the garage roof, connecting at the garage floor, then down thru the foundation to the storm sewer. I have a few around the outside of my house (all capped off now).
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
Unknown Pipe Used during construction otamywy Building & Construction 6 04-19-2015 11:24 AM
New sewer pipe for new bath in detached garage gante Plumbing 1 04-10-2011 06:14 AM
Cover Up Soil Pipe in Garage? mark2741 Plumbing 4 10-20-2009 09:29 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 12:07 PM
