Is This Union Ok Behind Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2017, 08:55 PM   #1
Is This union Ok behind walls
I'm Plumbing a shower and I was wondering if these can be concealed behind drywall without access per the UPC
Pipefitter56 is offline   Reply With Quote
Old 08-04-2017, 09:54 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,514
Re: Is This union Ok behind walls
Are you talking about shower outlet in this case?
Old 08-04-2017, 09:56 PM   #3
I'm transitioning from CPVC to Copper inside the wall Plumbing the mixer valve for the shower
Old 08-04-2017, 09:57 PM   #4
So the hot and cold inlets into the transition valve the rest will be Copper from the transition valve to the tub fill spout in the shower head
Old 08-04-2017, 10:35 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
Unions need to remain accessible- cover with an access panel.
Or transition using "sharkbite" couplings. Copper and CPVC have the same ID. Then no access is needed
Old 08-06-2017, 07:20 PM   #6
Rewards Points: 1,952
Sharkbyte safer.
Walls bowing out in large room hoffmandirt Building & Construction 8 07-14-2015 07:01 AM
Looking for confirmation these walls are not load-bearing walls jmai14 Remodeling 2 11-09-2013 09:28 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
