Union Nuts - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 2 Post By TarheelTerp
  • 1 Post By Yodaman
  • 1 Post By chandler48
  • 1 Post By TheEplumber
Old 02-22-2018, 02:11 PM   #1
Rewards Points: 6,580
Union Nuts
Is there a good reason iron pipe unions are made with a hex nut rather than a round nut? That's the way it's always been done isn't a good reason.
SeniorSitizen is offline   Reply With Quote
Old 02-22-2018, 02:14 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,702
Re: Union Nuts
One of those days huh?
TarheelTerp is online now   Reply With Quote
Old 02-22-2018, 02:21 PM   #3
retired framer
Rewards Points: 15,682
Re: Union Nuts
Unless a change would be an improvement the cost to change as well as challenging the market to changes may be to costly.
Unless there was an obvious reason the person bringing them to the job site would also be thinking, because that is how we have always done it.
Nealtw is offline   Reply With Quote
Old 02-22-2018, 02:48 PM   #4
Re: Union Nuts
Allow me to state it another way being cost to change always seems to be the hangup. Why were union nuts ever made hex rather than round from the get go? Yes, a change would definitely be an improvement.
There would definitely be a advantage to round being round is always less expensive to manufacture than hex.
And being open ended wrenches for a 2" union hex would be rather expensive and awkward the pipe wrench is the tool of choice anyway and the hex makes it aggravating for a pipe wrench.
Old 02-22-2018, 02:55 PM   #5
Property Mgt/Maint
Rewards Points: 8,202
Re: Union Nuts
Actually, I have seen both. I believe the union at the meter is round with a straight knurl.
Regarding cost to mfg. Might be a little less expensive to mfg round but not much. They are made from a casting, so only the added corner mat'l would be saved.
The hex is likely use full in the MFG process since the flats would provide a easy clamping surface.
Nealtw likes this.
Yodaman is offline   Reply With Quote
Old 02-22-2018, 03:02 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,312
Re: Union Nuts
Ayuh,.... I donno the answer, but,....
I've got a bucket of pipe unions, 'n many, of the same size, won't interchange with each other,......
Old 02-22-2018, 03:29 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 290
Re: Union Nuts
Flanges are round unions are square.......
I got theory- back in the day the used them smooth jaw monkey wrench things. They needed a square surface. That's all I got....
Sent from my XT1650 using Tapatalk
Old 02-22-2018, 03:31 PM   #8
Re: Union Nuts
That's just typical of the pipe plumbing industry.
Valve length for instance. Would be handy if there was a standard length, but that seems to be unnecessary until we get into valves of 2" pipe or larger.
Old 02-22-2018, 03:54 PM   #9
Oso954's Avatar
Rewards Points: 1,898
Re: Union Nuts
Because they are made to be opened and reconnected on occasion. You would chew them up if they were round. Why aren’t the lug nuts on your car round ?
If you are having a problem opening them, you are probably using a pipe wrench. It doesn’t have parallel jaws and isn’t made for unions.
If you use a parallel smooth jaw wrench on them they generally open and close nicely.
https://www.ferguson.com/product/ree...14/_/R-3575768
There is also a special adjustable hex wrench that can be used.
http://www.plumberscrib.com/ridgid-3...iABEgK_vfD_BwE
Oso954 is offline   Reply With Quote
Old 02-22-2018, 04:08 PM   #10
Re: Union Nuts
OH BOY, I had one of those wrenches in my hands once. Never again for the 60 inconvenience and aggravation in confined spaces.
Those unions that need to be operational often there are hammer unions for those situations.
Old 02-24-2018, 10:26 AM   #11
Rewards Points: 506
Re: Union Nuts
What? How the hell is it hard to use a pipe wrench with them. I'm a pipefitter who has opened and closed unions probably thousands of times using pipe wrenches, channellocks-type wrenches, crescent-type wrenches, and combinations of the above. I have never once wished for the nuts to be round. This makes no sense to me. My pipe wrenches work just fine on the hex nuts.
I have on occasion wished I had a way to operate three pipe wrenches at the same time, though.
bfrabel is offline   Reply With Quote
Old 02-24-2018, 10:55 AM   #12
Re: Union Nuts
The reason you don't know any better is because you've never had a pipe wrench on a round union nut where infinite adjustments of the wrench could be made. NEXT
Old 02-24-2018, 04:50 PM   #13
Naildriver
chandler48's Avatar
Rewards Points: 3,700
Re: Union Nuts
Oops, disregard. I thought from the title we were going to discuss Unions and the people who run them. Sorry. My apologies to those who like them.
I do find pipe wrenches handy, but man do they booger up brass. I had a guy who worked with us at the airport who "traveled light" with his tools, meaning he only carried a pair of channel locks. He could booger up gas fittings coming and going. I could tell when he had preceded us.
Bondo likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-24-2018, 05:16 PM   #14
Plumber
Rewards Points: 290
Re: Union Nuts
It hit me on the way home today from a goodwill service call at my son's house.
I was there troubleshooting why he had a short supply of hot water. I ended up replacing a single handle tub cartridge.
I remembered the old 2 handle tub fillers. They used round union nuts.... I think that's the only time I've seen them.
@Chandler I'm one of those channel lock guys..... but only on rough in work
chandler48 likes this.
Gorilla Nuts vs wire nuts with wings poiihy Electrical 12 08-25-2015 01:04 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
How to fasten heater element nuts under dishwasher? darsunt Appliances 0 12-03-2009 11:21 PM
Gas line union installataion diggerdave Plumbing 5 02-14-2009 12:59 PM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 09:07 AM
