Underground Water Line To Garden/rv Hookup - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2017, 05:09 PM   #1
Underground water line to garden/rv hookup
Hello,
I'm wanting to run a water line under ground to a few yard hydrants, 2 for the garden and one for a future rv hook site. I'm planning on using 1" cpvc pipe. Total distance is about 200' with about a 2ft drop in elevation total along the run.
I understand the bigger the pipe the less loss in pressure etc. I have an outside faucet on the house which is where I wanted to tie into the water supply, this is only 1/2 copper. Am I wasting my money with the 1" cpvc? Will the existing 1/2 pipe limit the flow to that of 1/2?
Sent from my VS988 using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 09-19-2017, 05:31 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,248
Re: Underground water line to garden/rv hookup
using 1" cpvc pipe
Ayuh,.... I'd use black poly pipe,....
Yer flows will be somewhat limited by the small pipe size,...
What kinda flows do ya need,..??
Usin' 1" will insure you'll have All the flow that's available, regardless what's upstream,....
Old 09-19-2017, 06:53 PM   #3
RRH
Rewards Points: 1,476
I agree. And it will be cheaper, no joints, easier to install and more durable.
Just make sure you use 100% stainless hose clamps. Some are called stainless but the screw is not.
RRH is offline   Reply With Quote
Old 09-19-2017, 07:05 PM   #4
Ok yeah looks like poly pipe is a better option. I was thinking cpvc originally because you can use it for potable water. Looks like you can with poly pipe too
PVC water line underground installation. maddog1 Plumbing 5 04-07-2017 09:34 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
