Under The Sink Plumbing Is Too Short. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By BIG Johnson
  • 1 Post By Yodaman
  • 1 Post By TheEplumber
  • 1 Post By Yodaman
Old 05-04-2017, 12:52 AM   #1
Rewards Points: 16
Under the sink plumbing is too short.
Hey Y'all,
I recently replaced the bathroom sink, however the plumbing is short. I tried the accordion-style flexible drain pipe, it still does not reach.
What are my options?
How do I unglue the pipe from the wall and extend it? Is that recommended?
On sink end, Is it possible to add a solid PVC Pipe? I really don't like the accordion-style flexible drain pipe.
Thanks!
Under the sink plumbing is too short.-imagejpeg_0.jpg   Under the sink plumbing is too short.-20170503_203344.jpg   Under the sink plumbing is too short.-20170503_184223.jpg
Chris305 is offline   Reply With Quote
Old 05-04-2017, 05:58 AM   #2
Rewards Points: 898
Re: Under the sink plumbing is too short.
That picture is really bad. Usually you have a nut and a friction seal but yours looks like it might have a bead of caulk. If it's caulk, you should be able to use a pipe wrench (or by cranking the trap arm with your hands) to break the seal and pull it off. You might have to cut the fitting off with a sawzall.
MTN REMODEL LLC likes this.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
BayouRunner (05-04-2017)
Old 05-04-2017, 06:29 AM   #3
Property Mgt/Maint
Rewards Points: 8,202
Cut it off and glue on a new sch 40 x tubular trap adapter. You will also need a new longer trap arm.
Yodaman is online now   Reply With Quote
Old 05-04-2017, 07:00 AM   #4
Plumber
TheEplumber's Avatar
Probably best to purchase a new 1.5" trap and a rigid tailpiece extension. Also get the trap adapter shown above as well as some glue and primer.
You cut the tailpiece ext. to the length you need to match the trap outlet- which looks a tad short also. Thats why you need the trap adapter. It allows you to adjust the length of the piece between the trap and the wall.
The Following User Says Thank You to TheEplumber For This Useful Post:
bensplumbing (05-04-2017)
Old 05-04-2017, 07:07 AM   #5
Rewards Points: 18,972
No way would I put a wrench on that fitting.
If it is glued and someone tried to stop a leak by applying caulking it's going to break something far harder to fix.
I agree adding that trap adapter is the way to go, it would also make it far eaiser to snake the drain behind the wall.
Loose that flex drain and use the right one.
http://www.homedepot.com/p/Everbilt-...90BG/205153709
There avalible in different lenghts and can be cut if there to long.
Old 05-04-2017, 07:20 AM   #6
Rewards Points: 6,408
How is the picture bad?
Old 05-04-2017, 11:46 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
Sorta is to me also senior.... I can't tell what the connection is.... doesn't appear to be an adapter or a HO make-do coupling.....
MTN REMODEL LLC is offline   Reply With Quote
Old 05-04-2017, 12:37 PM   #8
Property Mgt/Maint
I don't recognize it either, but I think we can all agree it needs to be cut off.
Old 05-04-2017, 05:47 PM   #9
Rewards Points: 898
It's blurry and out of focus.
Old 05-04-2017, 05:50 PM   #10
Rewards Points: 898
That's what you want but make sure you remove the trap arm first or you might end up with the end of the TA falling down and getting jammed in your drain pipe.
Old 05-05-2017, 03:01 PM   #11
Breakin' Stuff
Rewards Points: 1,374
If you go to your local hardware store they have all kinds of fittings. You can get a straight piece coupled with the flex piece to make it long enough.
Also like the other's have mentioned it would be best to replace that odd connection coming out of the wall. That will also give you more piping options.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Add Sink To Existing Bath Plumbing pinkfloyd43 Plumbing 4 12-19-2012 11:48 AM
Kitchen sink plumbing problem AlexHouse Plumbing 2 08-06-2012 10:55 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
