Under Sink Help - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 2 Post By joed
  • 2 Post By rjniles
Old 10-13-2017, 12:51 PM   #1
Rewards Points: 54
Under Sink Help
I recently had to replumb under my sink, (I removed the garbage disposal), and the picture below is what I came up with. There is a small drip (leak) coming from that fitting with the arrow pointing to it. I can't tell if it's coming from the top of that fitting where white meets black, or if it's coming from the bottom of that fitting. I've never used one of those flex pieces before. I replaced the cone shaped gasket that goes in there but it still leaks.
Any advice is appreciated. I despise plumbing for this reason. Something ALWAYS leaks and it's a P.I.T.A. to find it and fix it.
Sremed60 is offline   Reply With Quote
Old 10-13-2017, 02:38 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,936
Re: Under Sink Help
Get rid of the flexy thing and rearrange the pipes so that the sink drain go straight down into the trap.
joecaption and ZTMAN like this.
The Following User Says Thank You to joed For This Useful Post:
Sremed60 (10-14-2017)
Old 10-13-2017, 06:53 PM   #3
rjniles2's Avatar
Rewards Points: 4
Re: Under Sink Help
The tee joining the 2 sinks should go straight down to the trap. Get rid of the accordion tail piece.
Sent from my RCT6203W46 using Tapatalk
rjniles2 is offline   Reply With Quote
The Following User Says Thank You to rjniles2 For This Useful Post:
Old 10-13-2017, 07:18 PM   #4
Rewards Points: 18,964
Re: Under Sink Help
Your next post may be the trap will not line up where it connects to the tee even if it's turned all the way around.
A whole new PVC trap with a longer tail piece is less than $10.00.
Tail piece cut to size.
Old 10-14-2017, 03:34 PM   #5
Rewards Points: 54
Re: Under Sink Help
I know I'm going to have to reconfigure the pipe coming in from the wall. You're right, the tee doesn't line up with the trap no matter where I turn it:
The problem is trying to figure out where to cut that pipe coming in from the wall. It was already cut and spliced once so there's not much room. Wherever I can cut there's just barely enough room to glue a new coupling, so if I get it wrong I'm screwed.
I'm thinking of cutting it off here, gluing a 45* and then coming out straight. It still won't line up perfect but I think I can get it close enough so I can swivel the trap and line it up.
Old 10-14-2017, 03:45 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Re: Under Sink Help
Stop using the cement trap. Install a trap adapter on the pipe coming out of the wall and use tubular trap/fittings after that.
Mike Milam and mark_kershner like this.
My electrical answers are based on 2017 NEC, you may have local amendments.
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
