Under Kitchen Sink Possible Reconfiguration - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree11Likes
Old 08-22-2017, 06:34 AM   #16
Rewards Points: 18
Re: Under Kitchen Sink Possible Reconfiguration
Originally Posted by hkstroud View Post
Jeff,
I don't think I understand what you are saying.
Are saying that you add some pipe to the drain coming up, put on a 90, then put on a piece of horizontal pipe and connect the P trap arm to that horizontal?
The existing vertical 1 1/2" pipe that is coming through the floor of the sink base is usually copper. I extend that vertical pipe using a fernco to connect the existing copper and the new 1 1/2" PVC such that the end of the new PVC is roughly 12 inches above the floor of the cabinet. I then install a PVC 90 ell, a short piece of 1 1/2" PVC (aimed towards the sink tailpiece) and then a 1 1/2" trap adapter.
I then connect the new P-trap to the bottom of the tailpiece and the horizontal arm of the P-trap fits into the trap adapter.
I am not sure I am explaining it clearly. If you need a picture, let me know, and i will post one a little later today.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 08-22-2017, 07:58 AM   #17
hkstroud's Avatar
Rewards Points: 6,694
I think I understand but send drawing.
You may do this for convenience or other reasons but if I understand correctly, you still have an "S" trap.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 08-22-2017, 08:25 AM   #18
Rewards Points: 18
Waiting to go into a meetingnow. send a picture later, but it is no different than if the vertical drain came up in the 2x4 wall behind the sink, turned via a 90 to come thru the wall then a stub of 1 1/2" and a trap adapter.
Old 08-22-2017, 06:32 PM   #19
hkstroud's Avatar
But that drain pipe coming up through the wall continues on as vent.
An "S" trap is a trap that turns down before it reaches the vent, regardless of its shape.
SHR Plumber likes this.
Harold,
Old 08-22-2017, 07:11 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 302
You are describing s traps that are no longer code compliant because the vent- if it exists is below the trap weir
Old 08-23-2017, 07:23 AM   #21
Rewards Points: 18
I am in suburban Philadelphia and I have no idea why, but the codes here must be different than many other places in this country. I have mentioned a few times in the past that I rarely have seen the type of venting that seems to be code in many other places. I believe what we are allowed to do is called "wet venting" when the fixture is within certain distances from the main stack. I am not a professional plumber but I have done plenty of plumbing on my rentals. Below are before and after pictures of what I am describing. Townships have seen this many times and never brought up any issues with it.
Old 08-23-2017, 07:35 AM   #22
A "Handy Husband"
rjniles's Avatar
Rewards Points: 908
Jeff, even though you are using a P trap, your configuration is still an S trap. If it is allowed in your locality, it would be better to replace that 90 that turns down with a T and extend a pipe up to a AAV.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 08-23-2017, 07:47 AM   #23
Rewards Points: 18
Rj - please educate me... If the sink does not exhibit any gurgling or other issues, what is the purpose of that AAV?
Old 08-23-2017, 10:33 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 908
It will prevent the trap weir from being siphoned dry and allowing sewer gases to enter.
The Following User Says Thank You to rjniles For This Useful Post:
jeffmattero76 (08-23-2017)
Old 08-23-2017, 03:55 PM   #25
hkstroud's Avatar
Jeff
That is definitely an "S" trap. That is not wet venting. Chances are that it is permitted because that is how the build was plumbed many years ago.
If that drain pipe going to the basement ever gets completely filled with water, the water going down the pipe will pull the all the water out of the trap.
Same principle as when you use to siphon gas out of your father's car when you were a teenager. (Of course maybe you never learned to do that)
Because you have a 1 1/2" sink drain and a 2" pipe (it appears) that may not ever happen.
Installing an AAV will allow air to be pulled in instead of sucking the trap dry.
Harold,
The Following User Says Thank You to hkstroud For This Useful Post:
Old 08-23-2017, 04:58 PM   #26
Rewards Points: 18
Jeff
Thanks to all of you for the education. I have a few new wrinkles in my brain. It just amazes me that i have only once seen the type of venting that everyone here seems to refer to. Except gor that one exception, every drain from every sink I have ever worked on used an ell after the trap rather than a tee that had a vent pipe attached. I see pictures in plumbing books I have read that all show the type of venting you all reference and always wondered why i had never seen that type of drain/venting. Was what I am doing EVER code correct? All of the houses I work on were built in the 50s and 60s.
Old 08-23-2017, 05:00 PM   #27
Rewards Points: 18
One more question... With the type of venting you all are talking about, is there any limit as to how far the fixture can be from the main stack?
Old 08-23-2017, 08:01 PM   #28
hkstroud's Avatar
That is the time frame during which "S" traps were determined to not be a good idea.
There are a number of things that determine whether or not an "S" trap gets sucked dry.
Don't worry about it. As long as a "S" trap doesn't get sucked dry it functions just fine.
The AAV makes sure that the trap doesn't get sucked dry.
Apparently because of the age original plumbing the inspector can't make you put in a P trap which would require different venting. If you were to replumb the entire house he probably would.
If it ain't broke don't fix it.
Harold,
Old 08-23-2017, 10:30 PM   #29
Rewards Points: 1,952
His pipe does not look as if it is 2 inch. If it was 2 inch ID it would be considered combination drain and vent and code compliant. I sort of go with the inspector either does not know the plumbing code or does not care.
The Following User Says Thank You to Ghostmaker For This Useful Post:
jeffmattero76 (08-24-2017)
Old 08-23-2017, 11:39 PM   #30
Rewards Points: 996
You guys not in the trades would be amazed at the number of inspectors who do not know the codes, nor do they care. I am lucky to have two State Fire Marshalls that do know the codes and do care. Both are very helpful in my work.
fireguy is offline   Reply With Quote
Find the best kitchen sink for your kitchen sheila06 Appliances 1 01-28-2017 11:29 AM
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 10:29 PM
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
