Tying Into Dry Well Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2016, 01:21 PM   #1
Rewards Points: 1,128
The pipe you see in the pic is our current drywell pipe from our washer. About where I'm taking my pic is our tenants utility room where there is plumbing setup for a washer. My question is can I penetrate the wall and tie into our pipe so we are both draining into the drywell? Another question, if I'm able to do that what would happen if we were both using our washers at the same time? I assume it would back up. Anyway or anything to install so that wouldn't happen? Any input/advice would be great.
It's only two of them and me and my wife so there washer is not used a whole lot.
Mstrlucky74 is offline   Reply With Quote
Old 07-23-2016, 03:08 PM   #2
Re: Tying Into Dry Well Pump
Sorry about subject misspelling
Old 07-23-2016, 10:03 PM   #3
Rewards Points: 18,760
re: Tying Into Dry Well Pipe
I'd just be blow away if even what you have now would have ever pasted inspection in you location!
Exposed pipe on an outside wall, draining into a drywall, not into a septic of city sewer drain.
Need to be getting permits and inspection on this one.
Old 07-24-2016, 11:53 AM   #4
Rewards Points: 1,848
Not in my state. You would be scrapping the entire thing. Washers need to drain to a point of treatment, Septic or sewer. State EPA must approve of any grey water drainage.
Ghostmaker is online now   Reply With Quote
Old 07-24-2016, 03:40 PM   #5
Got it. I think I'll look into removing how ours drains. I really want to give my tenant washer and dryer. Any other drainage options besides busting up floors and tapping into main line? Thanks.
Old 07-25-2016, 04:22 PM   #6
Install a 2 inch stand pipe to a floor drain.
Old 07-25-2016, 05:45 PM   #7
Can you provide a little more detail? Thanks
Old 07-25-2016, 06:19 PM   #8
Do you have a floor drain in the area you want a washer machine?
Old 07-25-2016, 08:56 PM   #9
Re: Tying Into Dry Well Pipe
I don't remember seeing one... I'll check again
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
