Two Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2015, 05:34 PM   #1
Rewards Points: 26
Two water heaters
I recently bought a house that has two water heaters. A 40 gallon (propane) main one for most of the house and a much newer and smaller 17 gallon electric one that powers the master bathroom. The 40 gallon is on its last legs and I plan on replacing it very soon. My question is, I don't want to waste the new one but I also want to reroute the master bathroom through the main water heater because using propane is much cheaper than electricity here. Is it possible to feed the smaller water heater from the larger one so that if the smaller one were to run out of water, it would still be fed hot water from the large one?
zburtle is offline   Reply With Quote
Old 11-09-2015, 06:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,050
Ayuh,.... Replace the 40 gallon, with a 50 gallon, 'n remove the electric one,....
Then do a recirculator loop to the MB if it's that far away,....
I agree, Gas is the way to go over electric,....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
jmon (11-09-2015), zburtle (11-09-2015)
Old 11-09-2015, 06:23 PM   #3
Rewards Points: 26
Just curious, what issue does my solution have? I have no prior experience with plumbing so for all I know it could be horribly flawed.
Old 11-09-2015, 07:57 PM   #4
Rewards Points: 3,222
I don't know if that can be done. Please wait for the plumbers to respond to that question. Thanks.
Imo, Bondo has the best and easiest solution that will save you money and water.
jmon is offline   Reply With Quote
Old 11-09-2015, 08:26 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 182
The water between the 2 tanks will cool down when not used. So when you demand HW from the small heater, the heater will fill with cooled down HW. That's not much different than your current set up. But eventually it will fill with preheated water.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 11-10-2015, 02:59 PM   #6
Rewards Points: 3,290
Yes you can keep the small water heater at your master bathroom and feed it with hot water from the large heater. But the role the small heater now plays will be somewhat different than what you think.
Without the small heater, you will be running a lot of water down the drain waiting for fresh hot water to arrive from the large heater down in the basement.
With the small heater, you get almost immediate hot water with only a small number of degrees (probably not noticeable) drop as the slug of cool water in the pipe between the heaters commingles with the 17 gallons in the small tank pending the arrival of fresh hot water from the large heater. Little or no wasted water down the drain before your shower.
Because the small heater receives mostly hot water from the larger heater, the small heater will not run much.
But there is still some cost, the maintaining of the 17 gallons in a hot condition between usages using electricity.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
The Following User Says Thank You to AllanJ For This Useful Post:
zburtle (11-10-2015)
Old 11-10-2015, 03:13 PM   #7
Rewards Points: 26
That's true. I think both of you guys make good points. I think ultimately I'm just going to unplug and drain the electric heater and leave it be for now and then just reroute the bathroom to the main one. Water is pretty cheap here so if I have to waste a little bit that's ok.
Tags
heater , propane , water
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 03:57 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
