Two Shower Heads, 1/2 Pipe... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 01-04-2017, 03:47 PM   #1
Rewards Points: 14
Two shower heads, 1/2 pipe...
Hi all,
I've done quite a bit of Googling on this topic but I want to hear from this group.
I'm about to gut our master bath, where we have a standard shower with 1/2 pipe. I want to build a walk-in shower with two showerheads, and I'm obviously worried about the pressure if both showerheads are in use at the same time.
I don't have a way to run 3/4" pipe from the basement up to this bathroom, so I'm stuck using the 1/2" supply. Are there any options for me to boost pressure in the bathroom during this remodel? Any special values to use to help in a situation like this?
Thank you in advance!
Shane
Shane72 is offline   Reply With Quote
Old 01-04-2017, 04:24 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,832
Re: Two shower heads, 1/2 pipe...
With todays restrictive shower heads, normal 40+ water pressure, you'll be fine.....
plus, you both will be under the same shower head in no time..
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Ghostmaker (01-04-2017)
Old 01-04-2017, 04:28 PM   #3
Rewards Points: 1,928
I would add a valve so you can limit which shower head or both can be turned on at a time. Maybe a three way valve.
BlackTiger likes this.
Old 01-04-2017, 04:45 PM   #4
Rewards Points: 288
Just adding that the diverter valve would be if you want them both to run on the same shower valve. If you want separate temperature controls, then you'd have 2 shower valves and no diverter valve.
BlackTiger is offline   Reply With Quote
Old 01-04-2017, 05:03 PM   #5
Rewards Points: 18,960
3/4" would have twice the flow of a 1/2" pipe.
Low flow, less pressure.
No way to run a a 3/4" line! Why?
Old 01-05-2017, 07:25 AM   #6
Rewards Points: 14
Well, I don't have a straight shot to the basement...fire stops between floors + finished basement make it very tough. I don't think it's worth cutting into finished walls in order to get it done, as much as I would like to....
Old 01-05-2017, 08:43 AM   #7
Rewards Points: 1,414
Don't worry as much about cutting into finished walls, at least if you're just talking drywall. The skill-set to repair them isn't hard and if you don't want to spend time on wall-repair or are bad at it, there are a lot of people around who can do a serviceable job.
If you're talking a plaster wall or having to re-do the tiling, obviously, it starts getting more involved for a newbie.
Tom738 is offline   Reply With Quote
Old 01-05-2017, 04:47 PM   #8
Rewards Points: 288
1/2 pex is good for probably 3.5gpm. Let's say you are running 80% hot water at 2x2.5gpm. So your hot demand is around 4gpm and supply is around 3.5.
You'll have less than full pressure but still much more water than a single valve. It'll make a difference how hot of showers you tend to take. The cooler the shower, the more pressure you'll have.
As was suggested earlier it'd be advisable to have a diverter valve or 2nd shower valve rather than just plumbing 2 heads off one valve. That'd give you an option to have full pressure. That can even be done very simply by threading a valve in-line on the shower arm of one or both heads. Or can be done more fancy with a 3 setting diverter that matches your shower trim.
Shower Head Pipe 325_man Plumbing 14 08-09-2014 06:36 PM
Question about PVC drain pipe (shower) nighthawkix Plumbing 1 08-12-2012 07:37 AM
Walk-in Shower, cutting waste pipe kevin327 Plumbing 8 01-25-2012 10:42 AM
2 shower heads, delta/moen, cpvc/copper.THANKS chipraynor Plumbing 0 09-17-2011 02:41 PM
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
