Two 45's Versus One 90 Degree Fitting. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2016, 08:31 AM   #1
Rewards Points: 242
two 45's versus one 90 degree fitting.
I'm running water line under my house and have to cut into the cold and hot lines, so I was wondering how much more resistance is created by one 90 degree fitting rather than two 45 degree fittings, or since I'm using PEX...I might have room to create a curve rather than either of the previous.
Anyways...is it worth it.
I would appreciate any helpful comments.
Ed
Ed911 is offline   Reply With Quote
Old 11-28-2016, 10:09 AM   #2
Civil Engineer
Rewards Points: 5,246
Re: two 45's versus one 90 degree fitting.
The difference between two 45 degree fittings and one 90 degree fitting is so small you could not measure it. A gentle bend in PEX produces almost no friction loss, however the friction loss of either the ninety or the two 45's is small enough that it doesn't make any practical difference which way you go. If you want to see the psi loss through various fittings, check out this website, which gives you the loss coefficients for a variety of fitting types, for various sizes of pipe. http://www.metropumps.com/ResourcesFrictionLossData.pdf
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Ed911 (11-28-2016)
Old 11-28-2016, 11:50 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 18,194
As Daniel noted, no real measurable difference.
But what is important.....the number of connections. Every time you have a connection you have a potential for leaks...and the labor involved goes up.
Which ever method gives you the least number of connections is the best way to go.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Ed911 (11-28-2016)
Tiling 135 degree and 90 degree inner corners enkratesdiy Tiling, ceramics, marble 2 12-11-2015 06:02 PM
consequences if patio awning has a 10 degree fall instead of 5 degree LabRatte Roofing/Siding 4 08-13-2012 04:39 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-21-2010 11:53 PM
Compression fitting question JeffWireman Plumbing 9 03-07-2010 08:46 PM
