Tub Spout Splashing Water? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Mike Milam
Old 03-29-2017, 12:57 PM   #1
Rewards Points: 294
Tub spout splashing water?
My bathtub spout is spraying water around the back of bath rim and onto the floor, what could be wrong. This is a spout without the diverter.
Mikeron is offline   Reply With Quote
Old 03-29-2017, 02:08 PM   #2
Rewards Points: 3,424
Re: Tub spout splashing water?
There is a leak in the pipe coming out of the wall and going into the spout, or a leak at the joint where the spout is fastened to the pipe coming out of the wall or a leak in the spout itself just after where the pipe from the wall is fastened.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 03-29-2017, 05:47 PM   #3
Rewards Points: 18,974
My first guess would be someone cheaped out and used a galvinized nipple to make the connection from the spout to the elbow.
Old steel pipes will leak at some point 100% of the time.
Old 03-30-2017, 01:23 PM   #4
Mike Milam's Avatar
Rewards Points: 306
Some spout assemblies use an o-ring to seal the spout to the nipple coming from the wall as well. Depends on the style of spout you have. See if there is a set screw in the bottom of the spout where it meets the wall.
Mikeron likes this.
Mike Milam is offline   Reply With Quote
Delta diverter shooting water out of tub spout? Brand new installed system??? BERWYNpap Plumbing 11 02-22-2016 07:21 AM
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
