Tub Spout Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2017, 10:45 AM   #1
Rewards Points: 4
Tub Spout Removal
I am replacing the tub spout/shower diverter and can't figure out how to remove the plastic piece from the copper pipe. Any help is appreciated.
thanks.
Doglips is offline   Reply With Quote
Old 02-19-2017, 10:58 AM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Tub Spout Removal
An unusual tub spout.
Obviously you have remove the screw that holds everything in place.
Things now are probably just stuck.
First try tapping down on the metal insert. The screw you remove probably pressed against the pipe and pulled the metal bracket against the pipe. Tap and try twisting the PVC .
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-19-2017, 11:45 AM   #3
Rewards Points: 4
The metal insert moves freely and the PVC spins freely, but will not budge along the pipe even using a pry bar.
Mystery tub spout removal Irishcat Plumbing 13 04-02-2014 09:12 PM
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 03:12 PM
Removal of Tub Spout Remski Plumbing 2 09-11-2012 11:09 AM
Removal of tub with delta roman spout, faucets John stockdill Plumbing 12 09-11-2012 09:12 AM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 12:38 PM
