Tub Spout Not Flush Against Surround Wall... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 01-20-2018, 11:38 AM   #16
Property Mgt/Maint
Rewards Points: 8,202
Re: Tub spout not flush against surround wall...
Originally Posted by bassadict69 View Post
No set screws or anything that I see...
I have been unable to unscrew the spout...I am scared of breaking something loose inside the wall if I force it.
Good fear to have. It is hard for us tell from here how hard you are cranking on it, or where the breaking point might be. But if it doesn't feel like it is going to move, maybe better to just leave well enough alone and re-caulk. Worry about removal at the next tub/shower remodel.
The main concern is to prevent water from running into the top half of the spout. A little opening on the bottom is ok, allows for drainage if water does get in there. Scrape out the old and recaulk with kitchen and bath silicone.
Yodaman is online now   Reply With Quote
Old 01-20-2018, 03:25 PM   #17
Rewards Points: 363
Hard to tell, but there is an opening under the spout but all I feel or see inside is the copper tubing...
I think I will just recaulk and let it be!
bassadict69 is offline   Reply With Quote
Old 01-21-2018, 10:44 PM   #18
retired framer
Rewards Points: 15,226
Usually you would find a set screw there, your might unscrew or it might unscrew from the fitting in the wall. That is if there is a fitting in the wall and not just a copper elbow. First step would be to remove the caulking anyway.
Old 01-22-2018, 07:10 AM   #19
Rewards Points: 2,074
Hard to tell if that has caulking around the spout between the spout and the fiberglass. If it does you have to take a utility knife and cut all around the caulk to unscrew that spout . The caulk is stronger than hell. I would mess with it until I got it but there might be another way to make it look better cut the caulk if it is there and see if you can get a little flex behind the wall and try to push that fiber out a little to make it look better then put a board or shim behind it to hold it. I wouldn't put to much pressure on the fiber. I really don't care for the second recommendation just a thought. The Eustachian idea was good that was previously mentioned.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Tile shower surround meeting sheetrock on wall? forkandwait Kitchen & Bath Remodeling 3 03-01-2012 10:57 AM
Outside wall tub surround vapor barrier question shotsy Remodeling 3 03-30-2010 07:05 AM
Behind The Wall (Sheetrock) Surround Sound justme Home Theater 7 03-12-2008 07:14 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
