Tub Spout Not Flush Against Surround Wall... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 01-18-2018, 05:20 PM   #1
Rewards Points: 363
Tub spout not flush against surround wall...
This faucet spout is screwed onto the end of copper tubing that evidently is a bit too long. What is the easiest way to shorten the copper plumbing to allow the spout to be flush to the tub surround?
I do not want to remove the surround. Any other options to fix this?
bassadict69 is offline   Reply With Quote
Old 01-18-2018, 05:25 PM   #2
Guapo
Rewards Points: 11,950
Re: Tub spout not flush against surround wall...
I don't think that the end of the copper pipe is threaded. There could be a set screw underneath. Then cut the pipe.
Guap0_ is offline   Reply With Quote
Old 01-18-2018, 05:48 PM   #3
Rewards Points: 10,824
Copper pipe can not be threaded.
You either have a threaded fitting soldered onto a copper pipe --- if this is the case, first measure how much gap you have, remove spout, unsolder fitting, cut pipe by measured amount, re-solder fitting. After you remove the spout, measure overall length from tub to end of thread. Double check after resoldering that it is shorter by exactly the measured amount.
Or, you have a slip on spout, which is hold onto the copper pipe with a set screw from underneath --- if this is the case, remove spout, cut half inch off pipe, re-install spout. Of course, if you find the set screw, first loosen it and see if you can push the spout closer to the tub, stranger things have happened.
SPS-1 is offline   Reply With Quote
Old 01-18-2018, 05:49 PM   #4
retired framer
Rewards Points: 15,654
They come in different length, if that doesn't work solder a copper pipe in the fitting that fits in the wall and change the spout to one that just has a set screw and fits 1/2" copper pipe.
https://www.homedepot.ca/en/home/p.t...000514412.html
Old 01-18-2018, 06:21 PM   #5
Property Mgt/Maint
Rewards Points: 8,202
I can tell you how I do it, but unless your willing to buy a 1/2" NPT die, not likely to help.
I buy the shortest brass nipple that is long enough. They come in one inch increments. Assemble nipple and spot into place. Measure the gap, un-assemble, then cut the threads back the same distance with a die. I use a die set with holder and extended handles, but brass is soft and a simple die nut will work.
Nealtw likes this.
Yodaman is offline   Reply With Quote
Old 01-18-2018, 06:30 PM   #6
retired framer
So he could maybe get away with just cutting the one he has if he cleans up the threads after.
Old 01-18-2018, 06:40 PM   #7
Property Mgt/Maint
Depends on whats in there now. Looks like it will take 3 turns on the die. If he has a copper assy, that might be asking too much. Probably better to cut it, add a coupling and re-solder
Old 01-18-2018, 09:49 PM   #8
Rewards Points: 88
Whew, soldering with a torch that close to an acrylic wall surround could get tricky for a DIY'er.
I wonder if this would work for the OP a 5/8 in. O.D. compression coupling ? I would try one on my tub spout's pipe to shorten it before I would a flame solder or attempting to use a threader.. JMO though.
Gregsoldtruck79 is offline   Reply With Quote
Old 01-19-2018, 12:34 AM   #9
Rewards Points: 18,988
Need to remove the spout to figure out what was used to connect it and how it was done.
There's at least three different ways it could have been done.
#1, A solid pipe nipple most likely galv, steel which at some point will be an issue.
#2, Two copper adapters and a piece of copper pipe.
#3, An adapter and a piece of copper tubing with a slipped on spout.
Need to figure out how it was done first.
There's 0 need to solder anything close to the enclosure!
MTN REMODEL LLC likes this.
Old 01-19-2018, 06:57 AM   #10
Rewards Points: 363
Thanks guys...I will play with it more later today and determine exactly what I have.
Old 01-19-2018, 08:55 AM   #11
Peace be with you
DR P's Avatar
Rewards Points: 1,860
or you could consider an escutcheon:
https://www.homedepot.com/p/American...020A/203670902
https://www.lowes.com/pd/Danco-Chrom...tcheon/3515018
Peace
Gymschu likes this.
DR P is offline   Reply With Quote
Old 01-19-2018, 06:10 PM   #12
Rewards Points: 363
No set screws or anything that I see...
I have been unable to unscrew the spout...I am scared of breaking something loose inside the wall if I force it.
Old 01-19-2018, 07:14 PM   #13
retired framer
Fee under it close the tub for a hole it might be a set screw that takes an allan wrench. Then you undo the screw just a little and pull it off.
Old 01-19-2018, 07:32 PM   #14
Peace be with you
DR P's Avatar
Since there is a gap now at tub wall
How ridged is spout or does it flex up/down & side to side
if it moves easily it might be on CPVC stub ???
(which is not good but fixed lots of them were done that way)
what is directly behind the other side of tub wall ?
Old 01-20-2018, 10:55 AM   #15
Rewards Points: 363
It is pretty rigid, I can move it side to side very little.
On the other side of that wall is a counter and a very small cabinet.
joecaption likes this.
Tile shower surround meeting sheetrock on wall? forkandwait Kitchen & Bath Remodeling 3 03-01-2012 10:57 AM
Outside wall tub surround vapor barrier question shotsy Remodeling 3 03-30-2010 07:05 AM
Behind The Wall (Sheetrock) Surround Sound justme Home Theater 7 03-12-2008 07:14 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
