Tub/shower Surround - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2016, 08:32 AM   #1
Rewards Points: 155
tub/shower surround
I want to remove the old 1970 tile around the full size tub- Once I do that I wanted to put up the 3 piece "surround" instead of re-tiling. Are these meant to go right over the studs or do I need to put waterproof sheetrock first?
Huskyfan68 is offline   Reply With Quote
Old 03-04-2016, 08:52 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
depends on what type you get, they can be both ways..
WhatRnsdownhill is offline   Reply With Quote
Old 03-04-2016, 09:28 AM   #3
Rewards Points: 18,990
The best ones are attached directly to the studs, there at least 3 times as thick.
Pay attention to the install directions, often a few studs will need to be added to have something to attach it to.
Always best while that walls opened up to add 2, 2 X 6's laying flat in the wall where a door or curtain will be attached, and in the back wall where grab bars will be installed.
Sterling makes some good ones.
http://www.homedepot.com/s/bathtub+enclosure?NCNI-5
Water leaking around window in tub/shower surround Diane Quann Remodeling 1 04-21-2014 05:26 PM
Tiling tub/shower surround w/plaster & lath walls OurHouse Remodeling 60 08-02-2012 11:03 AM
Cement board in tub/shower surround not flat fieldstone Kitchen & Bath Remodeling 4 01-22-2012 10:36 PM
tub/shower surround 7echo Remodeling 1 10-05-2008 08:03 AM
