Tub To Shower Plumbing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2017, 12:01 PM   #1
Rewards Points: 4
Tub to Shower Plumbing Issue
Good morning!
I am converting a tub to a stand up shower. When I pulled the walls down, there was a lot of old water and termite damage, so I've had to re-stud most of the walls. My issue is that the plumbing for the space (hot and cold) actually come from the slab.
When trying to put up some 2x6 cross supports for my shower pan, I noticed that they actually seem to stick out from the edge of the studs, making them protrude from where the wall would theoretically be rehung.
Trying to get fixes or ideas for workarounds on how to get past this spot in my project! Can't figure out if I can attach pictures here, but I have some.
Thanks in advance!
JM
Jon-Michael is offline   Reply With Quote
Old 08-13-2017, 12:21 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,460
Re: Tub to Shower Plumbing Issue
You may have to cut dadoes in the cross support to where the pipes will fit. Then attach no-nail plates over it so you don't forget and drive a nail through them
Just more fly in the ointment. Have you changed the drain from a 1 1/2" to a 2" yet? Will you be centering the drain? If so, you have to dig up concrete anyway.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Jon-Michael (08-13-2017)
Old 08-13-2017, 01:07 PM   #3
Rewards Points: 4
That's kind of what I was thinking, thank you! I haven't converted to 2" yet, but I plan on leaving the drain off center and using a pitch system to get the gradient right for drainage. I think you nailed it, and once I pour in the shower pan, it should be fully covered.
Thanks again!
JM
Old 08-13-2017, 01:49 PM   #4
Naildriver
chandler48's Avatar
You don't "pour" shower pans, so if you need detailed instructions on how to do it, let us know, as we can link you to it.
Larry......
Tags
bathtub shower , plumbing , relocate , shower bath water lines
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Shower Plumbing Advice? ddawg16 Plumbing 17 08-31-2011 10:17 PM
Add shower plumbing to an existing bathtub Clock72 Plumbing 9 06-11-2011 04:23 PM
NorthEast US best nethod for plumbing an outdoor shower iamsaws Plumbing 0 05-11-2011 10:56 AM
