Tub Drain Solution? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2017, 03:34 PM   #1
Rewards Points: 28
Tub Drain Solution?
I could use your help with options for installing the drain on a freestanding tub.
The install is on a concrete slab, so what I have leftover from the previous tub is a square hole in the slab, dirt below, and the old P-Trap in the hole.
My concern is that the install instructions ask you to glue the final 1 1/2Ē FPT to Slip adapter which will then be inaccessible forever! You would never be able to perform any maintenance on the plumbing or fix a possible leak. Even Jacuzzi told me that the only way to get at the plumbing would be to destroy the $2-3k tub, or come up through the ceiling below, which doesnít apply.
This canít possibly be the only option.
The drain and integrated overflow channel meet and then go straight down into the P-Trap [see illustration]
Are there any products on the market that act more like a lav sink, where the drain pipe just gets inserted into the trap and could be pulled out if needed?
Here is a product video that shows this concept using what seems to be a rubber boot. It wonít work for me, but shows you the idea.
www.youtube.com/watch?v=TOVbFp-jBD8
8888 is offline   Reply With Quote
Old 04-04-2017, 03:47 PM   #2
Rewards Points: 1,928
Re: Tub Drain Solution?
Build a basement?
Old 04-04-2017, 08:43 PM   #3
Rewards Points: 1,054
Use a 1 1/2" compression fitting.
clarenceboddick is offline   Reply With Quote
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 12:59 PM
"custom" washer drain using rain downspout- venting question denemante Plumbing 5 02-13-2013 07:56 AM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
