Tub Drain Replace Or Leave As Is - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 01-20-2017, 08:36 AM   #1
Rewards Points: 31
Tub Drain Replace or Leave As Is
Renovating bathroom, while i have the tub out and the tub drain trap exposed, does it make sense to leave as-is or cut out and replace with PVC?
It's a brass tee, not sure the material for the elbows or straight run, appears to be copper or brass. all of it's 1".
Looks original, 1977.
Westbrook is offline   Reply With Quote
Old 01-20-2017, 09:49 PM   #2
Rewards Points: 1,938
Re: Tub Drain Replace or Leave As Is
Not good odds your new tub well have the exact same center. Cut it out use a all glue together tub waste with a new trap. And A proflex copper to plastic adapter.
BlackTiger likes this.
Do I need to replace cast iron drain? Nick1 Plumbing 5 04-10-2016 07:21 PM
Replace Bathroom Faucet Pop-Up Drain CraftyBobbie General DIY Discussions 3 12-02-2014 03:46 AM
How to replace drain to sewer connection – from pool jeffa123 Plumbing 4 11-27-2014 09:40 PM
Replace basement shower drain in foundation slab Paul_in_VT Plumbing 4 01-21-2013 01:47 PM
Replace tub's drain ring without removing tub? BradG Plumbing 12 03-17-2009 11:21 AM
