Tub Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By DR P
Old 03-18-2018, 07:23 PM   #1
Mike Milam's Avatar
Rewards Points: 314
Tub drain question
My new tub has a proprietary drain assembly. Photo of the installation instructions attached. It calls for a rubber gasket under the drain inside the tub. I did a test fit to get measurements to locate the drain plumbing. 'IF' I use that rubber gasket, the drain part that is inside the tub sticks up about an 1/8th of an inch. I'm not fond of that. The part I refer to inside the tub does 'not' screw in, rather it has a center ferrule bolt that screws into the part under the tub at the drain. I propose to use plumbers putty instead of the rubber gasket. What are you guys thoughts?
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is online now   Reply With Quote
Old 03-18-2018, 07:30 PM   #2
Rewards Points: 88
Re: Tub drain question
Hmmm, Mike,
Here is one I found not showing the washer. So I dunno....
https://www.keeneymfg.com/system/ass...gif?1260540352
Gregsoldtruck79 is offline   Reply With Quote
The Following User Says Thank You to Gregsoldtruck79 For This Useful Post:
Mike Milam (03-18-2018)
Old 03-18-2018, 07:33 PM   #3
Mike Milam's Avatar
Rewards Points: 314
Originally Posted by Gregsoldtruck79 View Post
Hmmm, Mike,
That looks exactly like mine minus the rubber gasket below the drain inside. Feeling better about using plumbers putty.
Old 03-18-2018, 07:52 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,862
Sure looks like a regular assembly with/out that washer... and plumbers putty or silicon interior seal.
BUT... any chance that you might have grabbed the wrong (too thick a rubber gasket) for that interior rubber gasket. A full 1/8 seems pretty thick to me.
Mike Milam likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-18-2018, 07:56 PM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
gasket would probably pull down closer to flush when torqued but putty is fine alternative...
do yourself a favor & carefully remove access cover to drain shoe &
apply generous amounts of silicone grease to all moving parts
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
Old 03-18-2018, 08:09 PM   #6
Mike Milam's Avatar
Rewards Points: 314
No, I double checked. It comes with just one option for the drain and one for the overflow.
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
"custom" washer drain using rain downspout- venting question denemante Plumbing 5 02-13-2013 07:56 AM
Center Drain Washine Machine Outlet Box Question Please Help!! joshua.easter Plumbing 9 07-23-2012 08:46 PM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 07:43 PM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
