Tub Drain Cover Won't Come Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2016, 04:38 PM   #1
Rewards Points: 331
Question
Tub drain cover won't come off
I have an old tub and I've tried to remove the drain cover but it won't budge. I removed the screw and I have a pair of thin needle nose pliers that I could get into the grate but it won't turn. The thin plier nose inserted into the grate is so little that I think I may crack it if I use too much force. I've abandoned the project for now but I may resume it later on. Does anyone have any recommendations for how to get it off?
Here's a picture of it:
Deck is offline   Reply With Quote
Old 04-07-2016, 04:57 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Tub drain cover won't come off
the disk is stuck with lime and corrosion--
spray with penetrating oil--tap very gently--spray again--
A lime solvent would probably work but might damage the plating.
Deck (04-08-2016)
Old 04-07-2016, 08:09 PM   #3
Rewards Points: 1,042
Vinegar is a mild acid, it might help dissolve the lime.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Deck (04-08-2016)
Old 04-08-2016, 06:30 AM   #4
SHEPLMBR's Avatar
Rewards Points: 178
CLR should work
SHEPLMBR is offline   Reply With Quote
The Following User Says Thank You to SHEPLMBR For This Useful Post:
Deck (04-08-2016)
Old 04-08-2016, 09:14 PM   #5
Rewards Points: 114
I would used CLR on it a couple of times to reduce the amount of buildup. If you have a round screwdriver with the same thickness as the holes I would insert it into one of the holes and use a hammer on the handle of screwdriver, its just an idea though. Make sure your turning it the right way also.
Check out all of my home improvement projects at http://www.homerenovationsandtools.com
Chrisathome is offline   Reply With Quote
The Following User Says Thank You to Chrisathome For This Useful Post:
Deck (04-08-2016)
Old 04-08-2016, 10:36 PM   #6
Rewards Points: 310
just break it off and replace with a drop in removable strainer for ease of cleaning.
PandJ is offline   Reply With Quote
The Following User Says Thank You to PandJ For This Useful Post:
Deck (04-08-2016)
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 07:56 PM
Floor Drain Cover - Advice? globus999 Plumbing 2 07-23-2010 10:40 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
3.5'' Brass Drain cleanout cover jeffmn Plumbing 6 01-13-2009 07:37 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
