Tub Diverter Not Flush With Wall - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By stevolution
Old 07-23-2017, 02:40 PM   #1
Rewards Points: 26
tub diverter not flush with wall
I just replaced the diverter/spout on the tub because the old one was leaking. Replaced it with a Moen slip fit spout which is what the original one was. Is it normal/ok the it did not sit 100% flush with the wall. There was about a 2-4mm gap between the fiberglass surround and the spout. I hate to assume things i don't know about, but do i just put a bead of caulk in there and smooth it out?
The copper pipe out of the wall is only 2.25" and i measured where the spout bottoms out so it's not hitting the pipe. It almost seems the the angle of the pipe is not 100% straight because the gap is larger on the top of the spout then the bottom and if i turn the spout upside down then the gap almost goes away.
stevolution is offline   Reply With Quote
Old 07-23-2017, 03:12 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,570
Re: tub diverter not flush with wall
If the gap almost goes away if the spout is inverted, the spout is bent or ill forged. I'd return it for a new one. Take the spout and stand it up on the countertop to confirm this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-23-2017, 03:26 PM   #3
Rewards Points: 26
This is kinda what i though, looking at the spout from the back the tube does not look centered 100% This is what it ended up looking like after install and caulk. I was not sure if this was normal or if i should return for a new one?
tub diverter not flush with wall-img_7319.jpg   tub diverter not flush with wall-img_7318.jpg   tub diverter not flush with wall-img_7321.jpg   tub diverter not flush with wall-img_7320.jpg
JERRYMAC likes this.
Old 07-23-2017, 05:05 PM   #4
Rewards Points: 1,938
Looks fine.
Old 07-23-2017, 08:00 PM   #5
Naildriver
chandler48's Avatar
I guess I was looking for a gap you could drive a truck through Yours looks good.
Larry......
Old 07-23-2017, 08:57 PM   #6
Rewards Points: 26
Great thanks guys. Looked like less then 5 mm gap. I'm just always second guessing myself with plumbing because of how much damage it can quickly do. Thanks Guys.
6" foundation step, then flush 2x6 wall dmtalon Building & Construction 2 04-29-2013 12:37 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
Drywall patch not flush with wall MRCook Drywall & Plaster 5 07-26-2011 05:12 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
