Tub Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2016, 07:25 PM   #1
Rewards Points: 398
tub connection
I pulled an original tub that was installed in 1971. The drain assembly kit just slid into the 1 1/2" pvc pipe that leads to the sewer pipe. Shouldn't this be connected? Should I add one of those threaded nuts that are used for sinks. It is a compression fitting. The other option would be to permanently secure it with glue, but that would seem like more trouble if I need to remove something.
It is a slab foundation. There is a small square cut out around the pipe. Should I fill it back in with concrete or just leave it like that?
Malcolm is offline   Reply With Quote
Old 06-05-2016, 09:52 AM   #2
Rewards Points: 1,854
Re: tub connection
You should have a P trap and a trap adapter if using a tubular tube waste.
What's the ideal connection for a garden hose bibb? Studly Plumbing 6 06-07-2016 03:46 PM
Range Electric/Gas Connection Master Brian Electrical 7 02-27-2015 09:07 AM
Low Hot water pressure after replacing laundry hose connection jp_jacobson Plumbing 4 05-03-2011 07:30 AM
Leaking Trap Connection bklusa1 Plumbing 3 02-17-2011 09:50 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
