Trying To Raise Sink Plumbing To Install Sliding Garbage Can - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By joed
  • 2 Post By rjniles
  • 1 Post By Ghostmaker
Old 09-01-2016, 04:55 PM   #1
Rewards Points: 50
Question
Trying to raise sink plumbing to install sliding garbage can
My wife wants me to install a retractable garbage can on one underside of our sink.
I've already purchased a unit from the brand Simplehuman and when I went to check the fit, the elbow under the left side of the sink is about 2 inches low (see the yellow arrow).
I've searched on some forums and like usual, there are proper and half-assed ways to get this done. Being a complete noob at plumbing, I was wondering if anybody would know how I could tackle this job?
Thank you kindly
mrrhtuner is offline   Reply With Quote
Old 09-02-2016, 05:16 AM   #2
Rewards Points: 18,762
Re: Trying to raise sink plumbing to install sliding garbage can
I'd remove everything there and start over plumbing it sort of like this. (picture the layout turned 180 deg. )
The whole thing can be done with slip fit fittings instead of glued like you have, also can be PVC not ABS as in your picture. (ABS is the black pipe)
https://www.google.com/search?q=doub...nGRSeyAAJ6M%3A
mrrhtuner (09-02-2016)
Old 09-02-2016, 05:32 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,596
Find a shorter garbage can?
Bondo likes this.
The Following User Says Thank You to joed For This Useful Post:
oh'mike (09-02-2016)
Old 09-02-2016, 06:03 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Shorten the 2 sink tailpieces and raise the horizontal pipe and trap up. I would also add an AAV to your non confirming S trap.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following 3 Users Say Thank You to rjniles For This Useful Post:
Ghostmaker (09-02-2016), mrrhtuner (09-02-2016), oh'mike (09-02-2016)
Old 09-02-2016, 06:48 AM   #5
Rewards Points: 50
Thanks for the reply and the photo. That does seem like it would give enough clearance for the garbage and storage, would work well it seems.
Looking at these reply's, I don't know why I didn't think of raising the main horizontal pipe and shortening the sink tailpieces.
Now I've seen this AAV/Vent stuff identified in certain posts but there is always some kind of negative comment(s) regarding it.
I understand that it would go at the end of the horizontal pipe just before the P-Trap but is there a reason why I should add it when everything seem's to flush fine?
Reading a post from 2006 by the locally 'famous' Mike Holmes, he states that cheater valves are not allowed in Ontario Canada.
I found another post regarding this also:
http://terrylove.com/forums/index.ph...vel-rim.14452/
The house I am in, I plan to sell in 3 years so I'd like to do everything as best as I can to prevent issues in the future (home inspector wise, etc...)
Old 09-02-2016, 07:56 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
The issue with an S trap is not that it doesn't drain well. The issue is it siphons the water out of the trap weir and allows sewer gas to enter the house.
oh'mike and SHR Plumber like this.
Old 09-02-2016, 01:26 PM   #7
Rewards Points: 1,852
Got to wonder if he actually paid someone for that piss poor sink drain.
SHR Plumber likes this.
Old 09-02-2016, 01:53 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I have seen this often on houses built on slabs in the 50s. Apparently S traps were legal. Not much else you can do without demoing the slab.
Old 09-02-2016, 03:16 PM   #9
Rewards Points: 50
Negative sir...I've only paid plumbers to clear the main drain 2 years in a row.
3 more years and I'm selling this house!
I will dig into this further this weekend(reading wise) and look at coming up with a few solutions and getting your guys feedback on it.
This house has put a significant amount of stress on me...all caused due to a half-assed home inspector that wasn't able to identify knob and tube from the breaker panel.
Old 09-03-2016, 01:14 AM   #10
Rewards Points: 38
I beg to differ, PLENTY to be done. Eliminate the s-trap.
SHR Plumber is offline   Reply With Quote
Old 09-06-2016, 01:17 PM   #11
Rewards Points: 50
Hey guys, so after looking this over on the weekend and doing some google searches, I am wondering if this would work well.
Since I need to get rid of the S-trap and an Air Admittance valve is not allowd under code here in Ontario, would I be safe to do this?
1st picture:
Have my vertical waste line run up from the floor and into a P-Trap. From there, I can connect both sinks at the end of the P-Trap.
Sorta like this....
This way, I can remove the S-Trap but route the plumbing according to what I can find on the internet and what other's have used.
If I am going all wrong about this, please let me know. I'd like to learn to do this myself.
Thank you
Old 09-06-2016, 01:48 PM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,140
AAV > No vent at all.
I prefer end outlet waste to center outlet. If you're cutting off the trap arm anyway you could swing it left or right whichever is easier and closer and gain even more space.
Those pictures give the right idea though.
And as a matter of fact, raising the trap arm may give troubles down the line if a deeper sink was needed or a g/d was to be installed. Using an end outlet allows the long tailpiece to be at one side of the sink while the other can be held up high for fancy garbage can clearance. Trap arm for sinks I normally plumb at 16" off the floor.
Journeyman Plumber
Old 09-06-2016, 06:56 PM   #13
Usually Confused
lenaitch's Avatar
Rewards Points: 1,720
I'm not much of a plumber but that ABS set-up looks new enough to have been installed after S-traps went out of favour.
I thought I read on another thread a while back that S-traps are rendered acceptable by having a tailpiece 'x' times the diameter of the pipe. Even if that's correct, I'm not sure if all of that could be tetris'd under there without complicating the flow.
lenaitch is offline   Reply With Quote
Tags
plumbing , raise , sink
Sink plumbing roughed in too high? Problem? BrianinDC Plumbing 16 02-10-2016 06:27 PM
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
garbage disposal under double sink debiasio Plumbing 3 01-02-2015 11:27 AM
Enough Space for Garbage Disposal and Deep Sink? jmai14 Plumbing 5 01-05-2012 07:56 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
