Trouble With Push Fitting Diverter In Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2016, 06:37 AM   #1
Rewards Points: 86
Trouble with push fitting diverter in kitchen
My kitchen faucet is suffering from low water pressure intermittently. Essentially, I turn it on, pressure is fine. Turn it off then back on and pressure is almost non-existent. If I then use the side sprayer, it "pops" it loose and pressure is normal again.
After researching it seems to be a common problem with the Pfister unit I have where the valve inside of the diverter either gets stuck or fails. The part is cheap to replace so I got under the sink to take a look yesterday.
Every manual, picture and video I can find for the faucet I have shows a plastic diverter shown here:
http://www.amazon.com/Pfister-951039.../dp/B004PUFJ5C
However, I have this one which is metal:
http://www.amazon.com/gp/product/B00...7GD52MAQNE4830
It appears to work and connect the same but I have no idea why it's there when everything I find shows the plastic one.
At any rate, I tried removing it to see if it is gummed up before buying a new one but I could not get the hoses off. All 3 connections are push-fit. I was able to get the bottom one off but not the other 2. There is not a lot of room but the one I was able to get off I could push in, get the collar down then pull the hose off. The other two though did not want to push in at all so I really couldn't get the collar down to pull them apart. Am I missing something here? I have no idea when this was installed but I would assume 5 years or so ago. Is there a different/better way to remove push-fit connections?
Blivit is offline   Reply With Quote
Old 02-15-2016, 07:47 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
its a good chance someone used some sealant on the hoses..heat is your friend..either a heat gun or hair dryer to heat but not burn the hoses will help get it off...
WhatRnsdownhill is offline   Reply With Quote
Having trouble w/ Kitchen layout CoconutPete Remodeling 67 01-21-2011 08:49 PM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 10:31 AM
Trouble removing kitchen faucet rebeccac Plumbing 12 11-29-2009 11:51 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
trouble fitting 4 wires into three demondope Electrical 11 12-28-2007 11:58 AM
