Tricks To Making PEX Fit In Small Area? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2016, 10:04 AM   #1
Rewards Points: 290
Tricks to making PEX fit in small area?
Excuse me for my stupid question:
I'm adding a hot/cold spigot to the house to replace a failing standard cold spigot. Since I'm plumbing the entire basement as well, I ordered a Spigot with PEX connectors, and I soldered on a ball-valve PEX stop onto the copper water supply.
I have abou 8inches between the spigot and shutoff valve: I already installed the spigot, and siliconed it as well.
Last night I decided to connect the PEX, and being the first time I've ever used it, ran into an issue: the PEX doesn't have enough flex to connect to the fixture to the supply.
Are there any tricks to this? Or do I need to cut the spigot out, and connect that way?
gizzygone is offline   Reply With Quote
Old 02-01-2016, 10:39 AM   #2
Rewards Points: 5,566
Not an answer but my inquiring mind needs to know why a stop valve is needed at that location.
Old 02-01-2016, 10:48 AM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
just soak the piece of pex in super hot water, you can even boil it and it will become like a limp noodle..
WhatRnsdownhill is offline   Reply With Quote
Old 02-01-2016, 10:52 AM   #4
Rewards Points: 290
Maybe I used the wrong term? It's a 1/4 turn shut off valve.
I live where it can freeze, so most spigots have shut offs inside the house... But it's also useful in some instances to keep people from stealing water. (I came home in my old home to find a contractor hooked up to my water supply fixing the cement sidewalks in the neighborhood without permission.... And water isn't cheap over here)
Old 02-01-2016, 10:54 AM   #5
Rewards Points: 290
Does it affect strength at all? Any issue using the Uponor PEX expansion tool with them hot?
Old 02-01-2016, 11:30 AM   #6
no effect whatsoever, after you have the pex on the fittings you can wait a few minutes till it cools down and then crimp...there are temp ratings printed on the pex tubing..
Old 02-01-2016, 11:33 AM   #7
Rewards Points: 290
Sounds good. Maybe I'll try a heat gun first? That way I can attach one end, cut to size, then heat the middle to add some pliability.
Old 02-01-2016, 11:37 AM   #8
that will work too, just move it around so you dont scorch the pex...
Old 02-01-2016, 12:07 PM   #9
Using PVC pipe, make a long radius sweep the desired bend and then push the heated pex in the formed PVC sleeve with a little extra length at each end. It will retain it's sleeved shape and be a lot less PITA to work with.
Old 02-01-2016, 12:38 PM   #10
Rewards Points: 290
It's a straight shot, so the PVC wouldn't work. But I think since I only have 8" of length getting enough bend to get onto the nipple is difficult.
I'd rather not try and remove the spigot so I'll go with some heat.
Old 02-01-2016, 12:51 PM   #11
you should be able to get that no problem, even if you kink the pex by mistake, just heat it up and it will go back to original shape with no weakening of the pex..
Old 02-01-2016, 01:47 PM   #12
Rewards Points: 290
I'll give it another go tomorrow night after I pick up a heat gun. Its located between joists and framing, so getting hands in there is tricky, let alone trying to work against the clock (PEX expansion fitting, so you only have a few seconds to work with)
Old 02-01-2016, 01:49 PM   #13
I dont like that type of fitting, I use the copper crimp rings..worse case senario use some shark bite fittings
Electrical / Ethernet / Surround Sound Setup for Home Theater area VikingDinKC Home Theater 24 10-15-2014 03:59 PM
Replace bath tub in small area johnsorious Kitchen & Bath Remodeling 8 06-16-2013 09:12 AM
Removing Wooden Floor Plank From Small Area GeorgeTyler Building & Construction 7 06-14-2013 09:40 PM
Patio ideas for very small area dinosaur1 Landscaping & Lawn Care 4 03-30-2011 04:12 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
