Is This A Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2016, 08:00 PM   #1
Rewards Points: 275
Is this a Trap?
Is this a trap?Never seen one like this, My Tub drain is going down very slow and this is on the line. Does that bottom silver plate screw off to clean this?Can't get it off its very tight.
lemley98 is offline   Reply With Quote
Old 05-15-2016, 08:15 PM   #2
Property Mgt/Maint
Rewards Points: 8,184
Re: Is this a Trap?
yep, yep and yep, going to need a good size wrench and a large bucket.
It is going to be a bit messy!
You should de-energize those circuits that feed the wires directly under the clean out plug.
Yodaman is offline   Reply With Quote
Old 05-15-2016, 08:31 PM   #3
Rewards Points: 275
Re: Is this a Trap?
ok ,Thanks
Old 05-15-2016, 08:33 PM   #4
Rewards Points: 275
Re: Is this a Trap?
Will i mess the seal up? Is there a rubber gasket or something?
Old 05-15-2016, 08:40 PM   #5
Property Mgt/Maint
Re: Is this a Trap?
Most likely there will be a gasket. You won't know what condition it is in until you inspect it.
When you re-assemble it brush the seal and mating surfaces with white teflon plumbers paste, it will help seal things back up.
Old 05-15-2016, 08:51 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,648
Re: Is this a Trap?
That is what is called a drum trap.
Old 05-16-2016, 04:28 PM   #7
Rewards Points: 1,862
Re: Is this a Trap?
I would strongly suggest you cut the drum trap out and replace with a P trap.
Ghostmaker is online now   Reply With Quote
Disposal to P trap Jamesonc Plumbing 16 12-05-2014 03:46 PM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
