Transitioning From 2 No Hub Cast Iron To Pvc - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By ct18
  • 1 Post By Ghostmaker
Old 11-08-2017, 11:18 AM   #1
Rewards Points: 960
Transitioning from 2” no hub cast iron to pvc
Can I use a no hub coupling to connect cast iron to a PVC 45 degree street elbow ?
Or do I need to use PVC no hub adapter fitting?
I also have a rubber 2” fernco, but that doesn’t seem to have that snug fit that the no hub coupling provides.
jaketrades is online now   Reply With Quote
Old 11-08-2017, 01:44 PM   #2
Rewards Points: 781
Re: Transitioning from 2” no hub cast iron to pvc
Shielded coupling only. Fernco connections are not allowed for sanitary in my area.
jaketrades likes this.
ct18 is online now   Reply With Quote
The Following User Says Thank You to ct18 For This Useful Post:
jaketrades (11-08-2017)
Old 11-08-2017, 01:55 PM   #3
Rewards Points: 960
ct18. Just confirming a shielded no hub coupling - like the one pictured (shorter of the two) -can be used to transition from CI to PVC?
Thx
Old 11-08-2017, 06:31 PM   #4
Rewards Points: 1,952
No hub is only approved for cast iron to cast iron. Since you are using 2 different materials you will need a pro-flex band that connects from cast iron to plastic. A mission brand will also work the bands are called transitional coupling's by trades men. In the plumbing craft.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Cast Iron to ABS - What Coupling? Jaxx Plumbing 1 09-17-2014 05:16 PM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
