Transition Cement Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2015, 10:42 AM   #1
Rewards Points: 33
Transition cement question
So I know that for there's a specific cement for ABS to ABS, and another for PVC to PVC, and that using the wrong cement on a given type of pipe will not work. But I have also heard that there is a 'transition' cement that can be used to bond ABS to PVC, and will work on both. So why not just use transition cement all the time? I'm assuming if it will work to bond the two different types of pipe, it will also work on the same types (i.e. ABS to ABS). Why bother having two different types of cement on hand?
jools is offline   Reply With Quote
Old 11-29-2015, 11:33 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 804
Not all AHJs will accept it.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 11-29-2015, 01:29 PM   #3
Rewards Points: 1,862
Dual plastic cement is not approved for use under IPC code. It might be for other codes.
All-tile shower. Wall to floor transition question. CoconutPete Kitchen & Bath Remodeling 2 09-30-2013 09:15 AM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 06:55 PM
Deck above a cement patio, footing question for the post Adamisu Building & Construction 1 05-25-2011 06:11 AM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
