Toy Stuck In Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 04-20-2017, 11:54 PM   #1
Rewards Points: 4
Toy Stuck in Bathtub Faucet
Of course one of my sons put a small turtle inside our bathroom faucet. Its lodged in enough where water wont push it back up, but just out of reach for fingers. I can see it. Tried grabbing with needle nose pliers. That just pushed it further in. Is there an easy way to grab it without removing the faucet? Thank you.
Thedude2741 is offline   Reply With Quote
Old 04-21-2017, 12:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,260
Re: Toy Stuck in Bathtub Faucet
Coat hanger with a hook bent into it. Other than that, just remove the outlet and push it out of through in reverse direction.
ZTMAN likes this.
Old 04-21-2017, 09:26 AM   #3
JUSTA MEMBER
Rewards Points: 3,828
There's a tool in my toolbox called "Mechanic's Fingers", it is a thin cable with a push button, that extends three hooks out to wrap around an object that is out of reach ( lost nuts), and pick them up.
This might get a grip on turtle, or disassembly.
ED
de-nagorg is online now   Reply With Quote
Old 04-21-2017, 10:20 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 18,428
Just unscrew the spout....
You may have to re-caulk where it meets the tile...but not a big deal
Or, if you have a Harbor Freight near by, they have this small tool set that includes a right angle hook type of tool.
Welcome to parenthood....it will only get 'better'.
You should see what it takes to get a plastic turtle out of a toilet.
ddawg16 is online now   Reply With Quote
Old 04-21-2017, 10:35 AM   #5
JUSTA MEMBER
Quoted from Dawg: You should see what it takes to get a plastic turtle out of a toilet.
Wait until you get a Rat-tail comb stuck in one.
ED
Old 04-21-2017, 03:35 PM   #6
sestivers's Avatar
Rewards Points: 477
Tie a loop in the end of some heavy string. Drop the loop end of the string down the drain on one side of the toy. Use a crevice attachment on your vacuum to suck the loop end of the string so it comes back up the other side of the toy. Feed the other end of the string through the loop, tighten, and then pull the toy out.
You might need a very small crevice attachment for this to work.
Steve
sestivers is offline   Reply With Quote
Old 04-21-2017, 04:12 PM   #7
Knows Enough to be Danger
Rewards Points: 1,295
I would agree on the bent wire hook approach. And then unscrewing it.
Keep us posted!
NickTheGreat is offline   Reply With Quote
Old 04-21-2017, 04:15 PM   #8
Rewards Points: 4
Awesome ideas. I'll give them all a shot haha not sure how to post pics but the faucet kinda looks like a swans neck. That why I was puzzled how to get access to it.
Old 04-21-2017, 04:30 PM   #9
Rewards Points: 1,932
Use plastic explosive it usually frees things up.
Installing new bathtub - centering faucet over drain SC Tiger Plumbing 12 10-13-2014 11:46 AM
Bathtub faucet help jmorc2003 Plumbing 2 12-20-2012 05:44 PM
Tub: Faucet handle part stuck on stem NoviceHomeOwner Plumbing 4 09-20-2010 08:35 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Bathtub faucet leak in wall seabreezz Plumbing 3 02-14-2009 11:59 PM
