Toto Woes - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By RRH
  • 1 Post By MoreCowbell70
Old 02-16-2018, 07:53 PM   #1
Rewards Points: 198
Toto woes
I have a "TOTO Drake Round Two Piece Toilet 1.6 GPF" that recently starting running non-stop after a flush. If I turn the water supply off to the toilet for a second or two and then turn the water back on, that stops the problem until the next flush. I did make sure the flapper was securely seated at the bottom of the tank, that doesn't seem to be the issue.
Here's a picture of it running - I am a complete layman when it comes to toilets so I'm hoping someone can identify what's going on in this tank.
Thanks for any help!
MoreCowbell70 is offline   Reply With Quote
Old 02-16-2018, 08:00 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,702
Re: Toto woes
Fill valves fail. Even on Toto toilets.
TarheelTerp is online now   Reply With Quote
Old 02-16-2018, 08:35 PM   #3
Rewards Points: 88
Re: Toto woes
Yep, I agree with Tar. Although Dorothy may be along shortly though, to chime in.
Gregsoldtruck79 is offline   Reply With Quote
Old 02-16-2018, 09:45 PM   #4
RRH
Rewards Points: 1,480
Re: Toto woes
Just buy a normal fluidmaster for about 10 bucks and replace the whole fill valve in about 5 to 10 minutes.
Like others said they do go bad, common item to replace.
https://www.homedepot.com/p/Fluidmas...-300755534-_-N
rjniles likes this.
RRH is offline   Reply With Quote
Old 02-16-2018, 09:59 PM   #5
JUSTA MEMBER
Rewards Points: 3,942
Re: Toto woes
Munchkins got to it.
Actually, the fill valve has wore out, and sticking open.
A replacement is a simple economic fix.
ED
de-nagorg is offline   Reply With Quote
Old 02-17-2018, 11:40 AM   #6
Rewards Points: 198
Re: Toto woes
Thanks very much for the quick input, I think I can handle replacing the fill valve.
I've been wanting to get the 'flush 'n sparkle' kit for a while as I have 3 kiddos that think flushing is optional. Seems like this might be a good time to do it as it comes in a kit, ie:
http://a.co/1aYUJ40
Any thoughts on if this would be an issue with Toto?
de-nagorg likes this.
Old 02-17-2018, 01:20 PM   #7
Oso954's Avatar
Rewards Points: 1,890
Re: Toto woes
Id measure flush valve. AFAIK, the Drakes come with a 3 inch flush valve.
That kit says its a 2 inch.
Id replace the fill valve with this.
https://www.amazon.com/Keeney-K830-1...PK2SAKQ20GGAY4
Then if you want flush & sparkle, just add the standard kit.
https://www.amazon.com/Fluidmaster-8...0001YLISS?th=1
Oso954 is offline   Reply With Quote
Old 02-17-2018, 01:25 PM   #8
Rewards Points: 198
Re: Toto woes
Great - thanks for the links I'll likely do exactly that.
Any advantage to the Keeney over the 'universal' Fluidmaster, below?
https://www.homedepot.com/p/Fluidmas...RP25/100554467
It's available locally and as much as I buy everything through Amazon I'd like to get this fixed today if I can.
Old 02-17-2018, 01:44 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
Re: Toto woes
No need to replace the flush valve, it is the fill valve that is the issue.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 02-17-2018, 01:49 PM   #10
Oso954's Avatar
Re: Toto woes
I prefer the diaphragm unit because it takes less space in the tank.
A) it gives you a bit more water because you dont have the plastic tower.
B) Ive got big hands, so the space is nice.
C) I havent used the unit you linked to, but have installed many of the diaphragm units from various mfgs.
Home Depot has one brand of it.
https://www.homedepot.com/p/PlumbPak...0-15/204374383
But its your choice as to which you would like.
Toto website that lists all the specs. of their toilets? jaes Plumbing 1 10-09-2016 06:52 PM
Sloan vs Toto flushometer? gizzygone Plumbing 3 11-26-2015 08:10 AM
Any good 3rd party flapper for Toto toilets? Homerepairguy Plumbing 7 02-08-2015 08:23 AM
Sloan be toto flush valve? gizzygone Plumbing 15 01-08-2015 03:01 PM
Toto toilet 'surging' when filling water cody21 Plumbing 3 07-20-2011 05:14 PM
