Is This Too Steep? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2016, 03:53 PM   #1
Rewards Points: 54
Is this too steep?
This is a 2" drain line. Should I cut this out and make it gradual? Will it pass code?
akajoe87 is offline   Reply With Quote
Old 03-06-2016, 05:45 PM   #2
Rewards Points: 54
Picture here:
Old 03-06-2016, 05:54 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 172
Yes, you are too cocked in the tee. Raise the tee till you have 1/4"ft grade on the 2" branch
The Following User Says Thank You to TheEplumber For This Useful Post:
akajoe87 (03-06-2016)
Old 03-06-2016, 05:59 PM   #4
Rewards Points: 54
I will have to cut out the 2" elbow. I dont think it will twist that far.
Old 03-06-2016, 06:07 PM   #5
Rewards Points: 54
Old 03-06-2016, 08:33 PM   #6
Rewards Points: 114
Definitely cut it out and redo it, bring it to 1/4" grade sloping down. I bet that pipe going into the tee y isnt fully in the fitting and will eventually fail.
Chrisathome is offline   Reply With Quote
The Following User Says Thank You to Chrisathome For This Useful Post:
Old 03-06-2016, 09:54 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 31,642
If you cut out the elbow your pipes will too short for a new elbow. Cut the pipe between the elbows and use a coupler. You can twist it any angle as you glue it back together.
The Following User Says Thank You to joed For This Useful Post:
ChuckF. (03-06-2016)
Steep Driveway Kierz10 Concrete, Stone & Masonry 16 03-06-2015 08:35 PM
wind storm knocks off shingle on steep peak sandyscamper Roofing/Siding 4 02-19-2013 06:50 PM
Ceiling fan issue - steep roof md2lgyk Electrical 4 10-04-2010 01:37 PM
Steep gravel driveway - washed stone? BRO931 Building & Construction 5 09-23-2010 02:06 PM
Need to pour a steep concrete driveway in sections? ChipsXJ Building & Construction 6 02-10-2010 06:34 AM
