Toilet Water Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By hkstroud
  • 1 Post By ct18
Old 08-23-2016, 08:32 AM   #1
Toilet water supply line
I'm putting in a half bath down in my basement and I believe I was told the water supply line goes in on the left side as you would be facing it or the right side if you were sitting down? What height? I measured the one upstairs and it's at about 6-7" from the floor.
Fortes fortuna e uvda. Fortune favors the brave
WolverineMarine is offline   Reply With Quote
Old 08-23-2016, 10:16 AM   #2
hkstroud's Avatar
Rewards Points: 6,684
Re: Toilet water supply line
Sounds good to me. Sounds good to me because that is what mine are plumbed to.
WolverineMarine likes this.
hkstroud is offline   Reply With Quote
Old 08-23-2016, 02:28 PM   #3
Rewards Points: 767
We would stub out high enough to miss base board trim. 6" should be fine but higher wont hurt.
ct18 is offline   Reply With Quote
Old 08-23-2016, 08:41 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Depends on the toilet you'll be installing, standard? or custom i.e. low with a skirt
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Code question about water supply line mprice214 Plumbing 4 09-13-2014 10:28 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 01:30 PM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
