Toilet Water Stop Valve Odd Inlet Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2016, 10:19 AM   #1
Rewards Points: 119
Toilet water stop valve odd inlet size
It seems most of my stop valves for my toilets and sinks do not fully shut off the water. I need to fix one of my toilets so I picked up a quarter turn valve to go ahead and replace the valve. I went ahead and also picked up a cheap pack of flat rubber washers for the Bibb screw.
The current valves are FIP inlet, I think they used some sort of nipple with a threaded end for the water lines. Well I picked up a Standard 1/2" FIP valve. When I tried to screw it on I found that the valve size was to big. The threaded pipe is smaller than 1/2". Luckily the flat washers I got were the right size and I was able to repair the existing valve.
With the valve working now I don't need to replace it, but if I ever wanted to replace it with a quarter turn, does know where to get valves that are not 1/2" inlet, that's all I can find.
wvphysics is offline   Reply With Quote
Old 01-09-2016, 10:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... It's probably 3/8" pipe,... possibly 1/4" pipe,....
Bondo is online now   Reply With Quote
Old 01-09-2016, 11:26 AM   #3
Rewards Points: 3,202
Depending on what kind of pipe you have, any local big box or plumbing supply store should have the appropriate adapter you need to make it work.
jmon is online now   Reply With Quote
Old 01-09-2016, 02:10 PM   #4
Rewards Points: 1,848
3/8 "was commonly used in older homes.
Ghostmaker is online now   Reply With Quote
Old 01-10-2016, 12:39 PM   #5
Rewards Points: 66
Agreed, 3/8 for the toilet not at all uncommon.
keithhe is offline   Reply With Quote
Old 01-10-2016, 01:22 PM   #6
Rewards Points: 119
Seemed hard to find 3/8 online. Homedepot didn't have any but I looked when walking around lowes and they have some.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Running water in toilet bowl - can't get it to stop acdc Plumbing 5 04-25-2012 12:05 AM
Is inlet valve required for "cold in" on water heater? joemontana16 Plumbing 8 11-29-2010 07:15 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
