Toilet Vent Layout Picture - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2016, 06:46 PM   #1
Rewards Points: 310
toilet vent layout picture
Am I able to vent a toilet this way? Want a 2" vent for toilet and will only be for toilet.
https://www.amazon.com/clouddrive/sh...hare_link_copy
PandJ is offline   Reply With Quote
Old 04-08-2016, 07:01 PM   #2
Rewards Points: 1,854
Re: toilet vent layout picture
You cannot dry vent any fixture under IPC below the flood level rim of the fixture.
The Following User Says Thank You to Ghostmaker For This Useful Post:
PandJ (04-08-2016)
Old 04-08-2016, 07:07 PM   #3
Rewards Points: 310
Same with UPC ? Also, to make sure my post is clearer, The 2" will have a 45 at the wall appx 12" behind it and go up above the fixture through the roof line as vent.
Old 04-08-2016, 07:37 PM   #4
Rewards Points: 310
How about this way with vent after toilet?
toilet vent layout picture-img_20160408_172157836-2016-04-09t00_29_03.180-.jpg
Old 04-08-2016, 08:51 PM   #5
You must maintain a consistent 45 degree or better angle. Any thing less in any part is illegal under IPC. What code are you under?
Old 04-08-2016, 08:53 PM   #6
Rewards Points: 310
UPC. Got it ,so no sweep or wye needed, just 45 off down "stream" of flow. Ok to 45 from at point near second pic ?
Old 04-08-2016, 10:25 PM   #7
Rewards Points: 310
This ok? It will be only fixture on this vent. The second is what i originally was going to do.
Old 04-08-2016, 11:15 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 170
I pipe as your first image shows, but it usually has the lave draining into it. AKA, wet vent.
Roll the 3x2 above the center line of the 3"
Old 04-09-2016, 12:53 AM   #9
Rewards Points: 310
hmm...so to be sure i under stand, when you say "roll", just have the wye straight up, then 45 off of that or 60 maybe?
Also, the tub drain could easily be drained into the toilet 4"(what I'm using) but I was concerned that a 2" vent would not be ok for both tub and toilet. I'm held to UPC here in my town
Old 04-09-2016, 01:30 AM   #10
Rewards Points: 310
i think this is what i'm looking for and what posters have suggested
No flat venting. Vent pipe inverts taken off above the center line of the drain. (UPC 905.1 & 905.2)
 Vents downstream of trap. (UPC 905.2)
Old 04-09-2016, 09:03 AM   #11
Plumber
Rewards Points: 170
Your picture shows the 2" above the center line of the toilet. In the end, your inspector will have the final say- he may say that is a flat vent and not allowed. I plumb under UPC and it is excepted in my region. But if you strictly interpret the code- it is not allowed except when structual conditions force you to do the flat section.
The tub will need a vent unless you design your system according to the UPC horizontal venting requirements. Or the tub can drain into the vertical section of the toilet vent
Old 04-09-2016, 05:36 PM   #12
Rewards Points: 310
Ok so I think your saying UPC ok with vertical drain off of a wye into watercloset drain before it gets to main vertical line(in my case). Is the pic ok? The 2" wye will be from tub. Also, can the 2" vent from tub serve as the toilet vent also through the wye?
I think this is the UPC that pertains to this:
706.2 Horizontal to Vertical. Horizontal drainage lines, connecting with a vertical stack, shall enter through 45 degree (0.79 rad) wye branches, 60 degree (1.05 rad) wye branches
Old 04-09-2016, 07:22 PM   #13
Rewards Points: 310
Here what I have modeled
Toilet, eye feeding tub drain and vent (45 in center), tub ptrap. Vent will be 2" thru roof for just these two fixtures.
I can also add vent upstream 4" vent on ground. It will be clean out
Old 04-10-2016, 09:54 AM   #14
Plumber
Rewards Points: 170
If you have that much room to plumb- do it like this-- It will be code compliant
Old 04-10-2016, 12:13 PM   #15
Rewards Points: 310
Ok so ok if tub drains in from above toilet. I will do this if below is not final option
One other question I have is it possible to vent upstream of 4" main towards cleanout? (see pic) There is a kitchen sink, bath sink that are vented with 1 1/2 " independently before going to main, and a laundry drain also vented independently before going to main, all downstream of toilet.
I'm trying to make flows as simple as possible from my rookie position lol
Can I install a basement toilet directly into soil stack and without a vent? oaktowngrrl Plumbing 3 01-28-2011 12:42 PM
Shower / Toilet Vent bigmatt Plumbing 2 12-05-2010 06:25 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
