Toilet Tank Leaking From Fill Valve - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By Nealtw
  • 2 Post By hkstroud
Old 12-21-2017, 01:33 AM   #1
Rewards Points: 38
toilet tank leaking from fill valve
water is leaking from the fill valve. i was going to replace the valve but not sure if the plastic white nut and washer are epoxied at the bottom of the tank or they can be removed?
i've seen videos where it was removed but not sure if all toilet tank are the same. mine seems harder to remove the nut, i have not forced it yet though.
brom123 is offline   Reply With Quote
Old 12-21-2017, 01:36 AM   #2
Rewards Points: 38
Re: toilet tank leaking from fill valve
pic is upside down..
looking at the plastic washer, it seems epoxied at the bottom of the tank..
are some tank like that? or all tanks, you should be able to remove the white plastic nut and washer
Old 12-21-2017, 01:37 AM   #3
Rewards Points: 38
Old 12-21-2017, 01:41 AM   #4
Rewards Points: 38
if it's epoxied i have to replace the whole tank
Old 12-21-2017, 01:44 AM   #5
retired framer
Rewards Points: 1,348
You can tighten the white nut there is a gasket in the the tank that could be changed by removing the valve. Clear all the water from tank before removing the white nut.
brom123 likes this.
Old 12-21-2017, 04:22 AM   #6
hkstroud's Avatar
Rewards Points: 6,082
I downloaded and expanded your picture. I see no signs of epoxy or any other adhesive.
I do see what looks like drops of water on the underside of the tank. If you do indeed have leaking in that area it is more likely from the tank to bowl bolts not the fill valve.
ZTMAN and brom123 like this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-21-2017, 06:24 PM   #7
Rewards Points: 38
thanks i will check again where the leak is. if the leak is from the bolt, do i need to buy a new tank or just replace the bolt?
Old 12-21-2017, 06:48 PM   #8
hkstroud's Avatar
You would just purchase a set of tank to bowl bolts and install. They come with rubber washers. Return here for instruction to install.
Harold,
One of the bolts on the toilet tank is leaking. blazito Plumbing 22 06-16-2015 09:01 PM
Toilet fill valve "refluxes" lison Plumbing 3 11-04-2011 11:16 AM
Slow filing toilet, fill valve already replaced SupraTT Plumbing 4 12-24-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
