Toilet Tank Doesn't Always Fill - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2016, 10:14 PM   #1
Solidify's Avatar
Rewards Points: 834
Hi guys,
I've got an issue with my toilet:
When I flush a line, the soiled water drains well, but the fill valve stalls and the water keeps running into that tall metal tube but the tank never fills up. If I move the fill valve's float up and down a few time, almost as to dislodge it, then let it be again, it usually ends up filling up afterwards.
Does this seem like a faulty fill valve? Can it be fixed or do I need to buy a new one?
Any help is appreciated.
Toilet Tank Doesn't Always Fill-imageuploadedbydiy-chat1472094869.358588.jpg
Toilet Tank Doesn't Always Fill-imageuploadedbydiy-chat1472094879.755581.jpg
Toilet Tank Doesn't Always Fill-imageuploadedbydiy-chat1472094890.258033.jpg
Solidify is offline   Reply With Quote
Old 08-24-2016, 10:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 170
Re: Toilet Tank Doesn't Always Fill
Best to replace the fill valve. I've actually seen this happen with new valves right out of the box.....
It's a small investment and a few minutes of labor
Old 08-25-2016, 07:10 AM   #3
ZTMAN's Avatar
Rewards Points: 604
You can clean those, but for $7 I would replace the fill valve.
If you want to clean, turn the supply water off to the tank. Remove the blue cap on the fill tube (it twists off with a quarter turn) Hold a cup over the fill tube, turn the supply on and let it flush. Turn the supply off, put the cap back on , turn the supply on. You should be good to go.
ZTMAN is offline   Reply With Quote
Old 08-25-2016, 07:49 AM   #4
Solidify's Avatar
Rewards Points: 834
Good advice. I just wanted to isolate the problem with this post. Definitely replacing the fill valve will rectify the issue?
Old 08-25-2016, 08:14 AM   #5
Civil Engineer
Rewards Points: 5,246
From your description, it may be that your flapper valve is not seating correctly, allowing water to leak out into the tank. Check the flapper before you replace the fill valve.
Old 08-25-2016, 08:34 AM   #6
Plumber
Rewards Points: 170
You mentioned the float hangs up. IMO, this is fixed by replacing the valve. For some reason, they sometimes loose alignment and don't slide well. I've never tried to figure out why, I just replace the valve.
Also, verify nothing is getting in the way of the float.
Sent from my HTC6525LVW using Tapatalk
Old 08-25-2016, 08:56 AM   #7
Solidify's Avatar
Rewards Points: 834
Will do. Thanks to you both. I'll keep you posted.
Old 08-25-2016, 10:20 AM   #8
Solidify's Avatar
Rewards Points: 834
I don't think the flapper is the issue since playing with the fill valve allows the tank to fill. Once it's full, theres no water leaking, so I don't think there's a problem with the seal.
Old 08-25-2016, 09:06 PM   #9
Rewards Points: 271
This was what I did when the water in my tank just kept flowing but the tank never filled up. It was a simple quick fix and it worked.
Druidia is offline   Reply With Quote
Old 08-26-2016, 09:17 PM   #10
Solidify's Avatar
Rewards Points: 834
Unfortunately that didn't work for me but replacing the entire valve did the trick. It was 23$ for me
Atleast it works now.
Old 08-26-2016, 09:35 PM   #11
Rewards Points: 1,832
They have whole rebuilt kits for like $20.
Jump-start is offline   Reply With Quote
Old 08-26-2016, 11:59 PM   #12
Solidify's Avatar
Rewards Points: 834
That's what it was. Everything minus the flapper, overflow pipe and tank lever. So essentially just the fill valve.
Old 08-27-2016, 07:21 AM   #13
ZTMAN's Avatar
Rewards Points: 604
Prices sound crazy in Canada. Atleast you fixed it.
Old 08-29-2016, 10:23 PM   #14
Solidify's Avatar
Rewards Points: 834
Yup, check out HD canada vs USA identical products and you'll feel my pain.
Mini-project: Rebuilt my toilet. First time doing it. r0ckstarr Project Showcase 6 05-13-2014 02:59 PM
toilet tank will not fill paulerrr Plumbing 1 08-31-2012 06:00 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
whistling toilet tank fill problem Need Advice Plumbing 6 01-16-2011 08:13 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
