Toilet Takes 4 Flushes To Flush - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2016, 01:02 PM   #1
Toilet takes 4 flushes to flush
We have replaced the flapper and used CLR(which oddly works for about 3 flushes) then goes back to before. You flush it. The water comes out of the spouts in the toilet and the tank drains. The toilet starts to flush then just kind of swirls. After four or five flushes it actually flushes. Or if you dump a bucket of water in the bowl, it flushes. Any thoughts?
TheYeti111 is offline   Reply With Quote
Old 05-15-2016, 01:21 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Re: Toilet takes 4 flushes to flush
Ayuh,.... Sounds like a blockage or atleast a participle blockage in the drain pipin',...
Old 05-15-2016, 01:24 PM   #3
When we dump a bucket of water in it flushes fine. That's the weird part. And when we put CLR in the tank...it flushes fine for about 3-4 flushes. We have snaked a wire down the flush hole...what else would we use to try and clear any blockage?
Old 05-15-2016, 02:17 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,714
More fibre in your diet? Sorry - couldn't resist.
If it truly is a blockage, maybe an old-fashioned plunger might help. Other thing to check: make sure the tank is filling every time; make sure the holes under the rim are not plugged. It's just as much about how much water is used per flush as it is about the force it is released.
lenaitch is offline   Reply With Quote
Old 05-15-2016, 02:38 PM   #5
Lol....Trust me, I've plunged the heck out of it. And the tank levels are good, the force of the water coming out does increase with the CLR added to the tank. We ran a wire up the spouts and they seem clear.
Old 05-15-2016, 03:58 PM   #6
Usually Confused
lenaitch's Avatar
You flush 3 or 4 times then it poops out (pun intended). If the water action seems to be the same each time, I'm wondering if you have some sort or venting problem and you're getting a vacuum lock that builds up over a series of consecutive flushes. A real plumber might come along and have some more educated thoughts.
Old 05-15-2016, 04:08 PM   #7
JUSTA MEMBER
Rewards Points: 3,122
I have a thought and past experience with a similar.
Get a toilet snake and use that to clear out a blockage.
I once found a rat-tail comb in one that had these symptoms.
The comb had gotten in with the pointed end first, would not go either way, until trapped in the snake coils, then it pulled out the bowl side.
ED
de-nagorg is offline   Reply With Quote
Old 05-16-2016, 04:33 PM   #8
Rewards Points: 1,848
**** impacted toilet or toilet with toy in the trap. Pull the toilet flip upside down and clean anything you see. Then Sit it up put an Auger through the top and make sure it runs smoothly through.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (05-16-2016)
Toilet Still Leaking After Replacing Gasket, Bolts, Fill Valve, Flush Valve wheeee Plumbing 24 08-11-2017 08:57 PM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 08:59 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 10:29 PM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 11:02 AM
