Toilet Suggestions - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2015, 06:03 PM   #16
Rewards Points: 426
I have Kohler . A couple are the old class 5,s cimmeron? elongated bowl comfort height.
They don't clog which makes me happy , they also don't rinse out as well as the swirly types ....wife not so happy ...I think she's overreacting. heh heh
I believe there is a newer model class 6 that has more of a rim rinse .
the handyman's secret weapon, duct tape
High Gear is offline   Reply With Quote
Old 02-11-2015, 06:04 PM   #17
Bob Sanders's Avatar
Rewards Points: 2,536
Originally Posted by Ghostmaker View Post
Depending on ones age I prefer the American standard right height Cadet. Very comfortable throne. Besides in 6 years I only plunged it once. That was my fault.
Cadet's are bloody good toilets. The flapper is oversized which makes the flush fast and powerful. It's hard to plug one of these. They come in both residential height and commercial hieght for the added comfort. We use them a fair bit in places where we've had frequent plugging problems.
Bob Sanders is offline   Reply With Quote
Old 02-11-2015, 10:01 PM   #18
iminaquagmire's Avatar
Rewards Points: 338
I'll throw in my experiences.
Kohler Wellworth, works but needs occasional plunging. Crappy design on the bowl to tank seal.
Delta Riosa, Its new, but it works well so far. Has proprietary internals and a small water spot, but does have a full skirt.
American Standard Champion 4, clogged fairly easily, was a pain to plunge, had a rough trapway, and the bowl was 1/4" off side to side on a level floor.
Toto Aquia III, NEVER clogs and dual flush. Very small waterspot and so harder to keep clean.
iminaquagmire is offline   Reply With Quote
Old 02-23-2015, 10:45 PM   #19
Rewards Points: 110
I installed a Kohler Cimmaron in my last place, didn't like it. Instead of a flapper they use a plastic cylinder that lifts up. The chain to the flush lever has to be fiddled with to get it adjusted just right. It seals with a rubber ring sort of like for a mason jar ring. If I went away for a week or more the ring would get stuck to the seat in the bottom of the tank. The whole thing is a highly developed bad idea.
manatee is offline   Reply With Quote
Old 02-23-2015, 10:49 PM   #20
Rewards Points: 110
What kind of flush valve does American Standard use? I need to replace 2 ancient toilets with something that is hassle free.
Old 02-24-2015, 12:04 AM   #21
JOATMON
ddawg16's Avatar
Rewards Points: 18,424
I have one American Standard in our original bathroom.....and two new Toto Drake II's in the addition. EASY to clean, flush very well and use only 1.2g of water.
I bought one of them off Amazon...I think it was $275....with free shipping. And, yes, it arrived intact.
ddawg16 is online now   Reply With Quote
Old 02-25-2015, 12:17 PM   #22
Rewards Points: 107
Toto Drake
Toto Drake Elongated with soft close lid. Flush fast and Efficient.
jerzeedivr is offline   Reply With Quote
Old 02-25-2015, 12:35 PM   #23
Rewards Points: 226
I have 2 cadet 1.6 gal toilets . They work pretty good no real complaints . The only thing you have to be careful of is the finish of the bowl . I would try to look at it before you buy .
daveblt is offline   Reply With Quote
Old 02-26-2015, 10:22 AM   #24
Rewards Points: 12
Toto - but expensive
We replaced our toilets with Toto 8 years ago. Excellent performance clogs are extremely rare compared to the problems of the previous toilets.
Comaboy is offline   Reply With Quote
On-going toilet issue(s) bknifefight Plumbing 4 01-03-2013 12:40 PM
Toilet Flushing Issues Chrishwa Plumbing 3 08-04-2012 12:13 AM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
