Toilet And Sink Both Drain Slowly - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2015, 02:59 PM   #1
Rewards Points: 221
Toilet and sink both drain slowly
One of my home bathrooms is kinda like the attached pic.
Both drain very slowly, sometimes, the toilet totally clogs up and has to be plungered.
Since both drain slowly, the toilet siphon is probably fine, the problem is further down the pipe, correct?
Should I use a drain snake? Thanks.
Toilet and sink both drain slowly-bathroom-extraordinary-bathroom-decoration-white-beam-bathroom-mirror-including-white-ceram.jpg
homenewbie is offline   Reply With Quote
Old 03-30-2015, 03:09 PM   #2
Rewards Points: 18,990
Most likely.
Any access under the floor so you can get to a clean out and use a real snake, not one of those small ones for a sink drain?
homenewbie (03-30-2015)
Old 03-30-2015, 03:10 PM   #3
Rewards Points: 221
Originally Posted by joecaption View Post
Most likely.
Thanks for guiding a newbie. I am considering some snake like this one:
http://www.homedepot.com/p/RIDGID-Kw...1348/203203829
Will that work?
Old 03-30-2015, 03:33 PM   #4
Rewards Points: 4,822
No, that's the kind Joe is telling you to avoid.
A bit spendy but more like this: http://www.homedepot.com/p/RIDGID-K-...4853/100595071
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
Old 03-30-2015, 03:35 PM   #5
Rewards Points: 221
Oh, I had thought that IS a real snake. Will that work for my clogged bath tub though?
And which one should I use for the clogged bathroom? Any recommendations?
Thanks.
Old 03-30-2015, 03:42 PM   #6
Rewards Points: 221
So, basically, a powered one. I might as well call a plumber.
The Following User Says Thank You to homenewbie For This Useful Post:
jmon (03-30-2015)
Old 03-30-2015, 03:45 PM   #7
ZTMAN's Avatar
Rewards Points: 628
For $30 dollars, give the wanna be snake a chance. If it doesn't work, call the man
ZTMAN is offline   Reply With Quote
Old 03-30-2015, 03:48 PM   #8
Rewards Points: 3,492
They're nice for small glogs that's about it. No good for the main line.
You can rent the big ones from any big box store. Before you do that, check for a cleanout on the main line somewhere. Or call a plumber as you suggested.
I agree with you, with it effecting both toilets, the clog is further down the line somewhere.
jmon is offline   Reply With Quote
Old 03-30-2015, 04:04 PM   #9
Homerepairguy's Avatar
Rewards Points: 1,114
Will that work?
That's a 1/4 inch, 25 foot snake for $29.97. If you get a 1/4 inch snake, suggest getting a plain one like this instead for $8.27. If you need to spin it, just use a variable speed drill on the end.
http://www.homedepot.com/p/BrassCraf...1015/100540673
If the 1/4 inch snake is too short, then suggest getting a 3/8 inch, 50 foot snake. Can spin that with a variable speed drill too (I've done many times with my wife on the drill and me shoving the snake down the line. This does require a path for the snake without sharp turns though. You might need helpers holding short lengths of 1/2 inch copper tubing at mid points. Once the clog is identified, tie a string on the snake before pulling it out and cut the snake about 6 feet beyond the string for easier usage next time.)
What ever you do, DON'T snake via your toilet bowl! If you do, you will scratch up your bowl with black marks. Remove the toilet and then snake down the toilet's drain line.
Also suggest buying both 1/4 inch and 3/8 inch snakes. If the 1/4 inch snake works, return the 3/8 inch snake later. If the 1/4 inch snake is too short, you will have the 3/8 inch 50 foot snake on hand while the toilet is removed.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-30-2015, 05:22 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 290
IMO, 3/8" is even too small for a 3 or 4" line.
Since you haven't run a large machine, I suggest you hire a small plumbing shop or drain cleaner to do the job for you. Or find a friend that can.
Also, request he camera the line afterwards so you know the condition of the pipe's interior.
I don't remember you stating where this bathroom is in relation to the rest of the plumbing, but there is a chance that the issue is outside of the house- such as roots- the machines listed won't be much help there.....
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (03-30-2015)
Old 03-30-2015, 05:39 PM   #11
Rewards Points: 582
after you use the plunger does it flush normal and does the sink drain any better....
Old 03-30-2015, 05:49 PM   #12
Rewards Points: 1,952
In a large pipe a 1/4 snake can tie itself into a nice knot and become very stuck. Do not use the wrong sized equipment.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (03-30-2015), Homerepairguy (03-30-2015), oh'mike (03-30-2015)
Old 03-30-2015, 05:59 PM   #13
Rewards Points: 582
running drain cleaning equiptment is an art by it self..and can be very dangerous... if you are unaware of the things that can happen while using the snake you can cause damage to you home... and to yourself... a man got to know his limitations
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 03-31-2015, 05:36 PM   #14
Rewards Points: 3,438
Barking up a different tree.
Has the venting of the stack (vertical line into which the respective fixture drain pipes pour) been verified?
The stack extends (should extend) through the roof where it has an open end.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Tags
clogged drain pipe
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Toilet slowly draining, sink causes level to rise emeryj23 Plumbing 4 09-04-2012 10:28 AM
Tub drain completely blocked. Snake no help. Sink and toilet fine. Whybenormal Plumbing 10 08-01-2011 10:55 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
