Toilet Seat Not Sitting Properly - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2016, 05:21 PM   #1
Rewards Points: 64
Toilet seat not sitting properly
Moved into a house and the bolt holes that attach the toilet seat to the bowl aren't aligned properly, so the toilet seat sits off to the side. Does anyone have any advice for how to align the seat properly so it won't move off to the side? I've tried tightening the seat in a variety of ways.
shan1289 is offline   Reply With Quote
Old 06-16-2016, 08:29 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,040
Re: Toilet seat not sitting properly
Assuming the problem is the toilet and not the seat, take the seat off and see if the holes in the toilet look symetrical to each other. It may be that the toilet was mis-cast; if so I'm not sure if there is much to do about it. They are usually larger than the seat bolts so you might be able to adjust it as best you can. If the nuts on the seat bolts keep coming loose, try some teflon tape on the threads.
lenaitch is offline   Reply With Quote
Old 06-17-2016, 07:20 AM   #3
Rewards Points: 64
Yeah, that's definitely the problem– the toilet was mis-cast and the bolt holes in the bowl simply don't line up. I just wasn't sure if anyone out there had maybe run into this problem and come up with a good fix.
The thing that gets me is, how did someone have this toilet for years and not notice? Or care?
Old 06-17-2016, 07:41 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Replace the toilet. If more than a few years old it is probably a water waster.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Unsure of How to Paint Old Toilet Seat & Lid blu878 Kitchen & Bath Remodeling 10 04-12-2016 06:52 AM
Toilet not flush with floor in front right!! L.Young Plumbing 1 10-09-2015 06:42 AM
toilet not sitting on floor evenly after flange replacement sajv Plumbing 3 02-24-2015 07:42 AM
Square toilet seat for bone colored American Standard toilet isteinhard Plumbing 0 10-23-2011 07:27 PM
Unremovable Toilet Seat, Please Help! Oliver126 Plumbing 22 12-05-2010 11:47 PM
